Spotted Snowy's R35 tonight. felt weak at the knees, first time in the flesh with one
sorry buddy never met you so didnt know who was who, my rudeness :D
burgandy r33 pretty stock at parkmore shopping center TOK-***
black ? r33 with aqua front bar and missing grill also in the same parking lot, just though i should of put cards on ... too late
  ss07 said:
Spotted a Holden Barina at Fountain Gate...
WITH A CANNON!
Fail :bunny:
Hey, you think that's bad?
Earlier in the week I saw an Astra with a QUAD CANNON! :D
Oh, and spotted: Purple R34 with clear tail lights in Dandenong today.
  Bart Japan said:
2230: White R33 on Punt Rd. Came up beside you as you were turning off into Bridge Rd.
Clean but someone has to teach me the difference betrween S1 and S2 rears.
S2 rears generally have the skyline garnish painted the same as the body colour, S1 are just clear like the indicators.
other than that ;)
spotted 2 r33's last night at knox parked outside timezone. a silver one and a red one. the silver one was about to leave but a cop rocked up behind it and it stayed there until it was clear haha and then when it left the exhaust vibration set off the red R33's alarm.
    • From my youth: GTi-R clutch change is a massive pain. The gearboxes are fragile? But the car is super cool and I want one 馃槩
    • Remember this is 1988 tech.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
