spotted 1 green r31 and green r32 with all cosmetics, kit, tinted black headlights...both looked like track cars
taking photos with fire trucks and police cars..either that or next to them at knox ozone in the car park opposite ultratune
white r32 on 'the force' (tv show)
the brainiac slashed his own tyres after it broke down so no one would steel it, and got arrested for having a foot long chef knife on his person.
:P
yellow gtt at park n wash cheltnham rd. had a chat. sorry mate forgot your name.
did you see the green R34 at ultratune on friday Beau? most prob with the same group of cars.
That was my R31 and Paladin's R32.4 - 2 of the 4 Team Ibisq Drift Cars..
We were doing a fund raiser with beaurepairs and the police and ses :P
Raised lots of cash for the SES so a very good day was had by all.
that R32.4 looks mint!
I dont see any yellow stickers??
Just saw a silver R32 GTR at the place I was picking up my bodykit from in Clayton. From memory there was a 33 out the front too.
Red R35 GTR going down Princes Hwy just then too. HOT.
And a silver R33 with stickers down the drivers door.
Far out, Callums car is finally done.
Looks amazing.
Only saw it for a second or two but I believe it was a Millenium Jade R34 GTR (Vspec NUR) around 2:30pm today driving along bay st in port melbourne. Everyones heads turned when it drove by. Sounded hot.
:P wo hoo spotted ......... although it is an M-Spec
R31 Skyline with Vic plates [ZZZ-999] Westbound on Dynon Rd, 7pm. Had aftermarket wheels with what looked like almost semi-slick compound (or just bald tires lol). Too dark and far away to see properly. Driven by middle-aged guy. Those plates are probably customised and worth more than the car lol.
    • I'm interested if anyone agrees with what you've said, and can give a good reason. Temperature of powder coating should be below any temperature you'd use to alter the wheel structure.  Powder coat typically 200 to 250. Annealing if that's what people are claiming would be occuring, starts at 300, and depending on the alloy, can need even up at 400+.   That's the only part I can think of that could cause an issue that people are believing it's from the rim losing hardness and becoming too soft.
    • Negative probe should be on the cars chassis. Positive on the wire.   Start as said above by unplugging everything (unplug the lights, and switches. Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch. If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.   Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.
    • Anyone know if it's a problem to powder coat forged alloy wheel centers (Rays/Volk GT-C). some say it's bad and can damage the alloy, some say it's not a problem.
    • Hey guys, I'm reviving an old post but I'm finally getting around to working on this now. I removed the battery to get a better look at the wires and i traced the wires from the headlight to the fuse box in the engine bay, but the wiring looks fine? The wiring for the R/H headlight is 3 wires and then is bundled up with the large diameter wire that goes underneath the fuse box. I didn't take it apart yet. I know you said that its a short circuit somewhere between the fuse box and the headlight. But could it be the headlight switch on the dash? Also, i pulled out my multi-meter and set it on the Ohms, but i'm not sure where to put the negative probe and the positive probe.
    • I have a 2 lt in Sydney. It was fitted on a R33 GTR, not used for several years . If you are interested email me on: [email protected] I'm not on this forum much .
