saw a white r34 gtt on the monash freeway outbound between jacksons rd till the sth gippy freeway. then saw a black r34 4 door with sau stickers blue parkers turn into edin rise shops as i was turning out. oh and aslso saw a r32gtst at monash medical centre car park, left a card on widscreen.
Theres a white 34 and black 34 that you might see cruising together. Owner of the white 34 is in my course at uni. Black one has bomex kit and dark rims yeh?
Yeh white 34 is mine and my bros friend. and the black one with bomex kit is my brothers but his rims are chrome with a little black in em. :)
Last night in geelong i spotted:
Black R34GT
White R34GTt?
Two tone green/grey s1 r33 gts
Yellow s1 r33 gtst (at eastern beach)
Dark Grey r32 gtst?
Black s1 r33 gtst full veil side kit. and white led tailights.
Nick. :D
yeh i was driving around friday night i own the black r34
spotted a 8-10 SAU skyline group out last night on the hwy. and saw UNR34L again. keep seein ya but never get to say hi lol.
spotted myself today driving a Nur Spec 34GTR ^
hey bud lol cheers again, yea i saw u aswell on the hwy, i tried to catch up but got cought up in the pack :down: all the skylines wer sik
Edited by s14_boosted
black R34 GTR parked at BP servo corner of rooks and canterbury. didnt look pretty cause both front and rear was smashed in and drivers side all scratched up :down:
hope you all good dude. car didnt look like it came out too well.
Yeh white 34 is mine and my bros friend. and the black one with bomex kit is my brothers but his rims are chrome with a little black in em. :thumbsup:
lol k, rims seemed darker because only saw it at night.
spotted silver 4 door R34 at Deakin Waurn Ponds
Saw Malz last night turning onto Nepean Hwy from North Road in Brighton. Hamish and I were getting ourselves a bucket of chicken and some grape drink in the Golf.
and some warermelon niggaaaaaaaaaaaaa
    • ...just a note of warning, you shouldn't drive it about with the TCU in limp mode with only 3rd gear available ~ apart from the fact you end up sheering the ATF at the torque converter interface, the high clutch in these isn't especially the strongest, particularly bolted to the RB25DE mill...which is likely a 4AX01 box with lighter duty high clutch (the RB25DET got the bigger high clutch)...be careful out there...
    • Hoping to do similar mods to my RB20 once I get it running and reliable again
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
