spotted a black r34 around 12ish today turning right into forsyth road jsut off the bridge in hoppers crossing today. beeped at me as i passed. had the window open and scared the shit outta me.
Thats me :D
thanks for the picture too!!!
I remember there was a R33 in there but forgot what color, might be urs.
lol...nw man..
i was the guy who has a big camera on me all the time...
the r33 white color that was under ur car when urs is being jacked up was my mate's(we were actually thinking of something dirty when ur car was on top,lol)...
mine was actually at tyrepower...we actually saw u when u pick up ur car..but was too busy looking at the ricer civic that only pull off 103kw...=p
Edited by toshirokato
saw your car outside the panel shop Charles, looks nice
Thanks buddy :P
My car is back at DT once again, because Vu is gonna try match the colour better after last week's respray, as the paint has harden now.
this morning at about 930 turning onto heatherton road from springvale road.... MNP R33 GTR SAU sticker... 400R front bar.
at the same intersection in front of us was a 33 GTST, custom purple, zorst aftermarket front bar.
The GTR might have been me I am usually turning right at approx that time most mornings.
Midnight Purple GTR?
lol...nw man..
Yea that Civic was bloody loud! VTEC YO. i was thinking "MAN, EVEN THOUGH MY CAR IS PRETTY STOCK, I WANT A DYNO RUN!" Haha. Unfortunately didnt see a guy with camera :P
How did you know i was picking up my car and that car is mine? Unless you were that guy who walked out later when i was hoping in the car.
Red 33 - red p & no rego parked on ground flr of regal parking @ fitzroy st - was there when i came in about 9 & still there when i left about 4:30ish.
White 33 on The Avenue, Sunshine about 5-5:30ish - I :P but don't know if you saw me.
Yea that Civic was bloody loud! VTEC YO. i was thinking "MAN, EVEN THOUGH MY CAR IS PRETTY STOCK, I WANT A DYNO RUN!" Haha. Unfortunately didnt see a guy with camera :(
the fat guy with a black tshirt u mean?? he is eskar..the white r33 owner...he is the one who told me ur leaving...
Spotted an awesome 34 gtt on springvale road last night, we were next to eachother. I had the window down and you dropped a gear and booted it. Your screamer pipe scared the shit out of me!
spottted the Greent Skittle down princess around 10pm heading outbound.
saw ADIS at station peer carpark.
Funny how you always see me yet i never see you....maybe you should paint your car fluro pink with bright led's all over it so i can spot you back :thumbsup:
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
