LOL @ "lady marks" nice one laith.
It shits me to tears when she tries to do her nail polish in the car... ...She gotten it on the dash once!!!... :D ...Put her foot up and did her toes while I was doing 100km/h on our way to Swan Hill... ...Hit a small bump in the road and blames me for her getting nail polish on the dash!!!... ...and when we go to the beach she has to put sun screen on IN the car!!!... ...IN THE F***ING CAR!!!...
Even that black shit she puts on her eye lashes... ...Dropped the brush once and there were black "lady marks" on the seat!!!... ...ON THE SEAT!!!...
Man... ...I swear... ...If my spine was flexible enough it'd just be me and the Skyline... :)
It shits me to tears when she tries to do her nail polish in the car... ...She gotten it on the dash once!!!... :) ...Put her foot up and did her toes while I was doing 100km/h on our way to Swan Hill... ...Hit a small bump in the road and blames me for her getting nail polish on the dash!!!... ...and when we go to the beach she has to put sun screen on IN the car!!!... ...IN THE F***ING CAR!!!...
:D
hital, you use a lot of full stops in your post... :)
Like how I use a lot of rofl's in my post.
Spotted a nice silver R34 GTR V-Spec with gold plated badging on Barkers Rd to day on the way to work, in Richmond.
Had an AVO sticker on it.
theres a white s1 33 always parked on balcombe road near seaview shops in beaumaris....looks nice and clean. if you're on here holla!
Yeah, I see this car every day. I guess the car lives in those apartments.
You live in the area?
yeah a few streets back toward black rock. don't see too many imports round those quiet streets...
Nice. I'm just in Beaumaris (next to the concourse). You might have seen me around in either a Supra, MR2 or 300ZX.
...Yeah I'm a car whore :P
Got a mate living in Beaumaris with a black GT-T. Have also seen a guy with a 180SX. Other than that, not too many imports around. I think it's a good thing :P Makes us look extra special.
firstly, spotted a standard looking white 33 p plater blond chic coming out of pinewood shops yesterday, followed by a short trip down to brandon park shops to see this beast parked.
i couldn't resist pulling up next to it for a quick photoshoot :P
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
    • Ha ha ha, so they stopped the bearings spinning on the one you want, but then decided the crank hub should slip instead 😛   Stick to RB, at least you can work on it yourself. And now it doesn't smell of vapour   Also I still believe there's a chance your new flap doesn't "pop", as even though the engine might breath hard, it has a direct path with no restriction to the inlet, which when on boost should pull a bit of suction for you. If you do get pressure in the catch can id be very intrigued. Time to put a boost gauge on it, and a session at the track, then solid cover your vent and do another session
