Kris, I will get you next time. lol
Leigh, was nice to meet you and even my partner who knows nothing about cars said you were a nice guy and clearly a car enthusiast not a hoon. It was good to show the type of people in SAU.
I am on Night Shift all week so on 11-7am.
lol i was gonna hop in Leighs car. i wonder if u woulda remembered me from when you got Kris the first time hahah.
no doubt will see you tonight then :down:
Spotted a Silver coppa with markings down the sides only tailing me from apple peel to Caltex on main road... either checking rego or waiting for me to do something stupid, did a u-ey at the Caltex roundabout. I guess they don't mind my Michelin Man sticker all over my number plate :)
Spotted a Maroon R33 heading onto the ring road from the tulla... as I accidently took the tulla exit instead of Melrose drive exit by mistake :P
Were you going towards Mickleham road exit and getting stuck with all the taxis on da road??
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
