Just spotted white r33, maroon r33 and dark blue r33 all in the one carpark at swinburne uni.
Also a white r34 a grey r34 4 door in the next car park. i was in the black r34.
Swinburne seems to be like a waterhole for skylines would be cool to meet some of you guys.
Spotted 50thousand cops patrolling all the way from cooper st to reservoir station HIGH STREET KEEP OFF IT!!!!
Yeah how bad was it!! They were everywhere, especially one marked station wagon which kept doing u-turn after u-turn patrolling directly outside epping plaza. I even watched it pull over a man and his daughter on their bicycles because they weren't wearing any helmets, lol. Inside epping plaza were officers patrolling the whole joint as well. Our streets have never been safer :/
Edited by GT32
LETHAL 6 or LETHL6 some sort of number plate combo like that
Red r34 GTT, Black bonnet
i have seen it a couple of time on the great ocean road on sundays...
any1 here own this?
his username is R-SPEC or something like that...
indeed.
Daz guessing you were the silver 33?
btw bonnet is red not black ;)
haha dunno where i pulled black from then... nah i have a black R34 GTT, but most of the time when i see you i have been riding motorbikes or in a ute.. ive seen you a couple of times inbetween lorne and fairhaven i recon. you drive down there a bit do you?
if im in my car next time.. il flash lights n wave! :P i always wonder if the skylines i see are off this
yeah most sundays if weather's decent and i got nothing else on i usually drive down to the GOR with a mate or 2 or if everyone's being weak im still there either way. by far the best and most relaxing drive you can go for
ahh dont really pay attention to bikies but i see a fair few of em there usually. beep us next time you drive past :worship:
if im in my car next time.. il flash lights n wave! :D i always wonder if the skylines i see are off this
    • I've uploaded logs / the current map to Gdrive if anyone has any ideas. https://drive.google.com/drive/folders/1FPnr22Z-EilG7tYdHSi0Qb07P2jfFLKV?usp=sharing
    • I'm running a Haltech Platinum Pro with the stock map for the RB20DET + tweaks for my build. When I started it this morning, the IAT was at 32F/0C (Outside temp was ~42F) and the AFRs went off the scale for my AEM gauge. I let it run for ~30 seconds then turned it off. I then did a smoke test, by hooking into a vacuum line directly behind the throttle body, and confirmed there was no leaks ( i let the smoke tester run for ~5 minutes / confirmed it was generating smoke before hand ). I then started the car again, after fixing a power steering leak.... and it seemed to be happy for ~30 seconds (was at ~11/12), but then seemingly shot back up to ~18 again. I then let the car run for a few minutes, thinking this was just cold start related, but the AFRs never came back down. I didn't let the car fully warm up, so maybe this makes sense, but I'm not sure what to do? The AFRs, when I last ran it, were normal, but because of personal reasons I haven't been able to break in the car. It was rebuilt last year. Engine / Mod list: Supertec pistons Spool rods Kelford 270 cams and Springs Stock crank Deatschwerks 900cc injectors Walbro 255 (Wired directly to the battery relocated in the trunk) NKG Audi R8 Coil packs + Conversion Harnesses from Wiring Specialties Holset HY35 turbo Haltech Platinum Pro ECU Haltech boost controller (wired in for high boost RB25 Neo transmission + needed bits for the speedo to work
    • Not great at getting the camera out fast enough for cars driving. Even in traffic. S15 is in front of the kei truck.
