Clean red SVD R31 with white wheels and personalised plates following me, this morning along Warrigul Rd.
Saw a white R34 coupe (not sure if it was a GTt or GTR from afar) along Dalton Rd Thomastown around 9am.
Spotted...
  1. white r32 gtr - dynon rd
  2. gray r35 gtr - also on dynon & followed it to droop st
  3. whole passels of skylines @ chasers
  4. white r33 - droop st/geelong rd
  5. burnt orange 350z - also on droop st
  6. forest green s14 - ballarat rd
  7. another forest green s14 - followed from mt derrimut rd into brimbank gardens
:down: was bored going home today so was playing spot the jap imports
Wine red R33 boosted it past me along St Georges rd.
I caught up at the red light - he kept looking forward....
Big NISMO sticker across the rear windscreen
I feel no love.
Why show off and not look at me? You obviously proved you can reach a red light faster than me.
on the other hand i cruised with a sexspec little fwd thing. so much kit chrome and candy green that i couldn't tell what it was, but it was turbo, and fast. took it very easy despite four or five commodores trying to race the both of us all the way down stud rd from knox. gave it a little hit to 80 at cheltenham rd from chandler rd lights, gave eachother a wave, and he turned off, i went home. guys in r33's are massive dicks in comparison
I feel no love.
See my diagram up top for an explanation!
I think I've had one R33 acknowledge me, ever...and that was the night I picked up my car :P
What pisses me off though, is that you know they know you're there...it must take some control to just keep looking forward like that and pretending you don't notice.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
    • It's a load sense idle up valve.
