Spotted Thread
paulr33
Often see a Grey/silverish R32 gtr on my way to work, on mt dandenong rd around the Croydon area. Black rims with tuff offset and black boot lip. Dunno if you're on here but that thing's awesome!
im guessing thats me lol :D
Spotted Red R35 GTR plate GTROAR parking on Toorak rd this evening, very nice car, and then saw another black/gun metal R32 not sure GTR or not but sounds nice along Toorak Rd just around the Monash freeway exit.
Spotted my dad in brunswick while going to check out an s15............. Funny how his got bigger plates too! lol
Whoever you are, lets go cruising, it'll be a laugh :)
Heres a photo :)
Haha 2 slow cars boosting it past you laith :)
My brother and mate. I'm waiting to see those cars written off. It will happen. Oh and try avoid unr3al. He has no insurance lol
I was stuck behind a little excel doing fifty... ...when I checked if it was clear to change lanes I saw CR34M about 500m back... ...so I just stayed there to check him out... ...didn't see UNR3AL until he went "tut tut tut" on my right side... ...then do you think I could change lanes after that???... ...I did get behind an unmarked cop that also looked like he was trying to keep up with them too... :P
I was stuck behind a little excel doing fifty... ...when I checked if it was clear to change lanes I saw CR34M about 500m back... ...so I just stayed there to check him out... ...didn't see UNR3AL until he went "tut tut tut" on my right side... ...then do you think I could change lanes after that???... ...I did get behind an unmarked cop that also looked like he was trying to keep up with them too... :)
haha owned
white r33 s2 between apple peel and tempy shops - exchanged waves :)
then in Heidelberg stuck in the normal bottle neck traffic near the ford and honda dealerships.. spotted a black r33 with the plates 'sicjet' guy looked at me i waved he ignored me and looked away - should of known from the 'sic' in your number plates not to wave hey..
lol!
33 arrogance?
    • Ultimately, if the tip is not far into the runner and the o-ring seals, then you are in business. Have you applied pressure to it as is? It is not really a problem for the injector to twist once it is bolted down, the oring seals it and you don't want it jambed into the oring too hard The plenum is intended to take multiple size lower injectors with different adapters, but the way you have it is fine if they seal.
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
