Cops seem to be out alot lately, I'm figuring its to do with the numbers game since it's almost June 30. They tend to try and catch up for the EOFY, up til about Sept, when they do as much work as possible, then go somewhere and die for a while.
Spotted quite a few cars all day today. Cops were also out in force. I've been seeing them roaming the roads a lot lately. Everytime I notice red and blue lights behind me I automatically think it's going to be me that they're chasing but every time it happens they always approach the rear of my car slowly and stay behing me for like a minute or so then speed off at like 150kp/h in the right lane again.
Red R34 GT-t along the Princes Fwy on the way to work in the morning whilst caught up in the traffic jam, then a white R32 GTS-t, Silver Evo 7 or 8 and another R34 this time in white all driving along Claredon Street throughout various times of the day. At the end of the day on Cooper Street, Epping I was driving alongside a white R33 GTS-t for a while before I turned off back on to the ring road (god, I miss having an RB), then caught glimpse of a black S15 ADM GT-Spec weaving through traffic along the Western Ring Road around the northern parts, also spotted a white FC RX7 sitting low with awesome looking stance (great fitment) and finally a red S15 Spec-R also along the Princes Fwy as I was approaching Geelong.
Hang on, one more... black R34 GT-t (I think) with ?chromies?! whilst I was turning right to head back home at the interection after I reached the end of the freeway, he was turning left into the small shopping centre complex.
Phew! Tomorrow, a new day of spotting begins again. :)
Edited by GT32
Also forgot to mention one more. Last one I promise!
I spotted GDZGTR again (actually driving this time, lol. normally I always see it sitting stationary) on the same street in Epping that my mrs lives on when I dropped her off tonight. If you're on here mate I was gonna give you a beep but had already gone too far. I was the white S15 btw. If I see you around again I'll give you a beep/wave :).
Edited by GT32
I only do them once a week now on weekends cos it's dark when I get home from work during the week :( I do miss doing them nearly daily
You would have seen me but I was driving my sisters excel turning into the middle hotel. My car is chilling at home till the defect is cleared. How often do you do the steps? I'm going to get back into it next week
Clean silver V35 350GT with white-on-black personalised plates drove past my car around midday today which was parked along Coventry Street, Sth Melb.
Had to park in the 45deg angled park all day for around $9 because for the life of me I can't seem to find decent (free) all day parking around that particular area. Yesterday I couldn't find a spot at all so I had to use the underground secure car park which cost me $25 for 4 hours! Cops were everywhere again all day today... It's just going to be a matter of time before I get pulled over again, I can already see it.
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
