must've been there bright n early haha
i found a parking spot out the front, and there was a silver 32R that was behind me, but i got it first.
when i got out, i realised if i had moved closer to the r34 in front, he probably could have JUST fit. sorry dude
was the r34 white 4 door because that was me and dont worry i didnt have trouble getting out
Just spotted so many skylines.
- Black 34 Gt -t parked opposite me at cheltenham shops
- Black 32 Gtr with 34 rims, passing me walking through the station alleyway. plates were 'jet' something..
Both looked amazing and loved the DIY front lip on the 34 matching my own :)
Seen that Jet R32 before,
Spotted just before at about 2:35 a fkcing awesome R34 GTR (Silver) cruising along beach road st.kilda, Looked like Goran's car... mate, if it's you... what a MACHINE!!! looks amazing!
LOL that was me , was thinking that aswell then i quickly did another lap but there was no room . All good , got a spot out the back whistling.gif
Just spotted the same R32 just then. Plates are JET-26. Looks so nice!
Spotted a white 33 gts p-plater in Main St, Croydon this arvo. Had black te37 replicas(?) probs the rota ones.
Also a big sticker on the boot saying "Spoon Sports". You realize Spoon is the Honda tuning company yeah? The sticker you're after is Nismo :thumbsup:
ROFL
Yeah that was me. Was on my way home from Chelt.
Saw the MR2 coming down the street I was thinking that was you and it turned out it was! Looked f#@ken clean man love the color.
Haha thanks man. Shame you saw it in such terrible condition (filthy and smashed front bar). It's normally very shiny and detailed, I promise :P
Have you had a respray? Your paint is like glass.
Spotted this morning:
White R33 GTS-T on Greens Rd. Had SAU stickers.
Also spotted Harsh today on South Gippsland Hwy.
:banana: finally got spotted....were you in your car?..damb i must have been blind not to see that sexy painted MR2 :P
Bloody curry :P
SHIK AS CURRY!!!! :nyaanyaa:
:worship: finally someone else thinks that same...
Nah, was in a blue stock-body MR2. Doesn't really stand out at all so can't blame you for not seeing me :P
Yeah i know the feeling been a while since i washed mine as well.
The entire front of the car has been re-sprayed so when i do wash and polish it it does come out like glass.
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
