Haha it's not that low! 34 looks so clean, I always see it at karoo so I'm assuming your a teacher, or some kids are getting dropped off in style hahaha
Haha yeah Cheers!, I'm actually the IT technician for Karoo, along with a few other schools. :)
Spotted JET26 again today while I was filling up at BP Mentone. Also spotted a white R33 in Seaview about 30 min ago.
Hi there!
Was on my way to work.
Your car is such an eye magnet its not funny. That red in sun light is awesome.
Followed WESTWD down Burwood highway this morning for a little while. Tried to catch up to you but too much traffic :(
Car looks nice, what are those tail lights?
They are custom made LED taillights. 666DAN sold them to me. You should see them at night time, look amazing!
EDIT: The lights have also been modified so that all 4 lights 'turn on' when braking, which i really like as with 2 door R34's only the 2 outer lights turn on when braking.
What were you driving?
Spotted a few R33s today-
A light blue R33 GTST with that front end conversion that uses BA headlights, around 11am near Meadow Heights train station. IMO; looked dirt, :down: sorry brah.
A white R33 GTST dropping a chick off near Galactic Circus/Crown around 5:30pm ithink. It had a MASSIVE blue stripey scribble flame sticker on the side. :ermm:
A white R33 GTST giving it a bit and making some ghetto gun fire down on Elizabeth street around 7pm, sounded so sex. Had a sticker of a angry turbo on it lol and jun sticker on rear quater panel, I think ive seen this car on carsales
EDIT: also spotted a wingless R33 GTS(T?) near Cragieburn station, idk why but that little step that R33's have between the boot and rear qpanels when u take off the spoiler/wing make me cringe.pinch.gif
Edited by JDMKiD__/ⓞⓞ-33
O3PEH in my car loving my subs haha
Absolutely LOVING the sounds in your car, and the music taste...now Mick from Riverside is going to make more $$$ off me lol. Good meeting you after all that "spotting" lol. :rolleyes::thumbsup:
Oh and :thanks: for the sounds demo :)
Absolutely LOVING the sounds in your car, and the music taste...now Mick from Riverside is going to make more $$ off me lol. Good meeting you after all that "spotting" lol. :rolleyes::thumbsup:
haha i knew id get you to want subs! i should ask mick for some commission ;):P
yeah good finally meeting you too and no probs :)
black r34 gtr on toorak road last night sxyg** was fkn nice
I spot this all the time. Looks f'king hot! It gets around too. Last time it got major spots it was seen in the east, west, city and inner city all in the one night from multiple spotters.
The car seems to travel all over Melbourne when it's out and about! At least it actually gets driven on a regular basis unlike most other BNR34's I know...
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
