i work at chiba.
and that was me, front end's busted, and its dirty as hell, but thank you, you the white 4 door @ kfc all the time?
The one in moonee ponds? just ate there last night was one of the best. My first and definitely not my last.
Spotted a few yesterday/last night!
Yellow 25GT yesterday parked outside Starbucks on Glenferrie road. Possible bomex kit.
Black R33 next to me last night on the eastern. Got off at Doncaster road.
And a gunmetal 33 doing a u-turn on Springvale road, just before Marrondah highway. Gave you a toot ;)
Spotted tonight on the way back from visiting the folks down plenty road - JETLNE was a black R34, looks nice and sounded insane, he was egging me to take him on with my soarer which by the sounds and looks of it wouldn't have stood a chance in hell running a stock ecu and obviously hitting boost cut with the dump pipes, exhaust, cam gears, cams etc until I get my mines ecu back next week haha Was an awesome looking skyline and sounded absolutely insane, made me wish my car had some balls which is why I'm wanting to buy a skyline :) Curious as to what kind of power it was pushing out???
Edited by jtims88
I see REQIEM and AFIRST almost daily. AFIRST usually on the Eastern @ ~5:15-5:30 and REQIEM usually somewhere between Heidelberg and Yallambie @5:30-5:45.
I've given you guys the odd g'day rev as I split past you :) I'm on the red/white R1 with Ventura rack and bag and Icon Variant helmet that you've no doubt seen and thought "what a f**king mad prick" as I piss off into the distance unencumbered by peak hour :P
Black R32.
Has been parked out the front of the local cop shop for a long time now. FMIC with DIY "HKS" painted on it, blue front/rear bumpers. Missing drivers side window so I presume stolen.
Anyone missing a black R32?
I have also seen it has been parked there for a couple of months now.
Also Saw a mint silver r34 gtr in Lilydale this arvo
Spotted a black R33 coming into the city today, up Spring Street and then you turned left into some road just after the theatre with everybody standing around. Had a sticker in the driver-side passenger window, but didn't see what it was clearly
Black R32.
hahaha the one in mooroolbark.. such a dirty 32
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
