Spotted Thread
paulr33
i always pass a black (or midnight purple) 33gtr a litlle further south. always gives me a wave too. when im in the 33 obviously.
he doesnt just wave at random cars looking for me.
This could possibly be me. I work down near hastings and pass a white r33 gtst my way down to work and back home. I try to wave if i see the car in time. Ive got a midnight purple R33 GTR Vspec with bronze rims. Havent put the SAU Vic stickers on it yet though.
Drove with a group of nice cars this arvo on warby hwy sevile, r34 gtr at the front then Audi Evo r35 then me in my daily shit box then a 350z behind me
And then Saw a nice blue 32 at Kilsyth wreckers
Edited by 0zhiph0p
It seems that my thread did not work :S
So I guess I'll post here given that it is a form of "spotting".
Anyways, I was looking for a wallpaper to use and came across this photo (Below) (if does not display can be seen here - link: http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=423882 )
An amazing photo taken in Victoria (Given the street / VIC plates) and was wondering if the owner is from SAU. I edited the picture slightly: removed the rego sticker (Bottom right windshield) and the car in the background (Magna - top right). Beautiful car and a beautiful picture - curious to see if the owner is from SAU. Cheers, Jeremy.
Spotted THR34T this morning in Cheltenham while I was dropping off a driveshaft to a mechanic.
I was in a Liberty, so clearly not spotted in return :P
yesterday evening, saw a lightning yellow gtt, silver lmgt4's, sau stickers parked on Alma road. looked noice
That was me :)
WHY SO MANY YELLOW 34S NOW????
Hahaha that's what I said when you bought yours :P
That was me :)
but back then there was two.
I've seen a yellow gtt on what seems to be avs 5s parked along lygon street brunswick stretch more than a few times already.
    • There is a LOT of stuff that can be done, it all depends on how much time and money you want to spend on doing in.  Not all ECUs will be able to do it, and the more control you need the more time and knowledge needs to be put into making it work.  If you're willing to spend the time and money and have the right hardware and skills involved there's a lot that can be done.
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
