the other day on princess hwy, black r33 gtst s1 with ferrari emblem on front quarter and gtr badge on the back......seriously mate what the f*ck is goin on there?
LMAO people like that make me laugh
I once saw a gts-t V-Spec must be worth a fortune seeing as its the only one i have ever seen ahhahah
love how every monaro pulls up next to me wanting a go then backs off as soon as they hear the turbo spooling.... ahh the only advantage of having no air filtration at all :thumbsup: zzzzzzSSSSSSSSSSSSSSSSS
nice red r34 on sydney rd, nismo kit/gold rims
Edited by R-SPEC
Spotted a silver r32 on highstreet in melton
black r33 on highstreet in melton, down the westlake end, he gave me a stare then fluttered his blow off valve as he took off from the lights
spotted him again i think, about 20 mins later at the east maccas in melton
black 34 going down james cook drive in melton
May have been me, but i didnt go to maccas, itr wouldve been me if it had the big wing on the back. Could this be the first spotted for me??? hahaha. Dint mean to stare if i did, didnt see what you were driving, my platyes are 'siklin'
Edited by Damo_c
i've seen siklin in the past couple of days but i cant remember where. so yeah thats two spots for ya
didnt see the plates lol
i was in a white r34... it was at the lights near james cook drive on highstreet
I saw this r34 gtt last night completely covered with 'BURSONS' advertising!!
Does anyone know the car n wats up with it; the dude must own a shop franchise.
Im going for a drive now; they see me rollin' they hatin' ridin dirty'
AWD DRIFTING ?? hahah
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
