Was at a set of lights and along side i hear 'doof doof' so i just look straight ahead but I cant help but notice in my peripheries that the driver with his arm out the window was giving me 'the STARE' for about 10seconds mind you which is not comfortable for a heterosexual.
Anyways turned out to be some ford foulcum with [iAMFPV] plates
Is anyone else sick of "the stare" unless its a member of the opposite sex?
hahahaha yea man i got 100 of those last night people stare at you like they want to start trouble with you when will they learn
spotted a cop on my way home from racepace yesterday... she almost pulled out in front of me (then decided against it as there was NO room) causing me to jump on the anchors and give her a 'you gotta be kidding' stare and head shake... which I then decided was a pretty bad idea lol
saw like skylines on beach rd last night.
orange 33, silver 33, black 34, black 34 4dr, and 2 really nige 33gtst's
i nearly had an acco with a cop the other day too... he was turning into a street in front of me when part of his arial fell off so he stopped and got out as quick as he could.... forgetting 1 tiny detail... THE HANDBRAKE!!!... lucky i wan't going fast and was able to stop as his car came reversing infront of me...
i'm sure it would have somehow been my fault :D
was on hoddle street last night at about 6:30pm stuck in the peak hour traffic, had a white r33 gtr pull up next to me and then the next lane over a r34
and i was thinking 'what are the chances 3 skylines in a row in peak hour!
spotted a chick in a 33 with white rims on princess hwy, near webb st at about 7.30 yesterday
were you in the grey 32 I think its my shit box your talking about? If so hi :)
spotted a white R33 Series I on the way to work on Bangholme rd i think thats how u spell it...... Anyway he was pulled over 3 people out side the car looking at the car prob took that corner trying to show off and lost it and stacked trying to show off to his mates, would not surprise me its a very dangerous corner.
    • Thanks heaps Duncan and GTSBoy. I'll get my old man to sit in the driver's seat and turn it on and off while I test with the meter. Or maybe other way round, depending on whether he remembers where his glasses got to
    • This is the GTR fuel pump. Yellow shows 12V, orange shows earth. The ECU provides the earth to activate the fuel pump relay. The ECU side of teh relay will pull low when the ECU activates. This is the RB20 fuel pump. Almost the same, but a little simpler. You can see I indicated (above) where the 12V line goes down to the RB20 diagram on the overall diagram, whch shows both RB26 and RB20. This is where I show it coming in on the RB20 diagram below. You can see that the dropping resistor is handled differently. When the fuel pump control is not providing earth to the pump, the pump earths through the dropping resistor and thus runs at lower voltage (some is wasted over the resistor) and runs slower. I showed that "not 12V and not quite earth" portion of the wiring in a paler orange. The rest of the wiring that I did not colour on that little section below the pump would be orange when the fuel pump coontroller is providing earth. This drop is handled inside the fuel pump controller in the GTR. Regardless, you can see where 12V is supposed to be, where earth is supposed to be. The key on prime is via the ECU providing the pump for only a few seconds the switching off. You should be able to see that happen.
    • Yeah so when you turn key to IGN the fuel pump should run for a few seconds. If you find the fuel pump relay (and have a multimeter, and a second person) to can check the relay inputs.  One trigger pin should be either fully earthed  The other trigger pin should get 12v from the ECU for say 3 seconds when you turn key to IGN, and at all times that key is at START (note, I said this from memory, it may be the other way around, ie one pin always has IGN 12v and the earth has continuity to earth when you turn the key) One Pin should have a good battery voltage The last pin goes to the fuel pump + Also note that if the power to the relay is good, and the relay is working, it is worth checking the pump has a good earth too. There is a computer in the standard system that increases the earth resistance to slow down the pump when not required, pretty old school and it may have failed
    • All this talk about fuel and fancy ECUs, meanwhile my poor old R32 has neither.... When the ignition is turned on, should there be power running o the fuel pump constantly or just for the few seconds it usually takes to prime the pump? About to go have another look at it, have watched some YouTube vids on how to use a  multimeter and looked at some wiring diagrams but really have NFI what I'm looking for because electricity is invisible
    • Yuh....but weren't all the supertourers, except maybe the Audis, FWD? I don't recall any of the others being AWD.
