comming home from work along bell street i spotted skyline tail lights up ahead so eventually i kind of caught up and saw a white r33 s2 doing a u-turn @ the lights where mcdonalds is, had SAU stickers on back windows >,< - doubt they would of seen me :)
spotted R34PER at Re customs just before.
man i like your cooler ... is that a just jap item ? any illeagal cutting to the front bar ?
Its a blitz cooler, came on the car when i got it but from wot i can see i dont think much has been cut out and it uses stock cooler pipe holes :banana:
comming home from work along bell street i spotted skyline tail lights up ahead so eventually i kind of caught up and saw a white r33 s2 doing a u-turn @ the lights where mcdonalds is, had SAU stickers on back windows >,< - doubt they would of seen me :D
Sounds like me! Around 10-10:30ish?
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
    • Meanwhile you could come down for a coffee tomorrow. Details in the events section
    • sorry dude i forget about the forum sometimes. sent you a pm
