yesterday morning saw a black r32 with sau stickers going down fleetwood drive and today saw a black r33 with sau sticker on the top of the windscreen turn into saxonwood drive. oh these r in narre warren lol
Spotted the winfiled gtr on the monash, not up to date with my merc models but i believe the one in the pic is one of the extremely rare gullwing models.
guy i work with his brother owns the 'winfiled' gtr, on the weekend i was at some race track, forgot what one he mentioned,
they were there with a r35 GTR skaifey behind the wheel comparing the two. can find out more details tomorrow, but thats the gist i got this morning
BTW: spotted a Silver R34 GTT with green stickers down the side a SAU sticker in qtr window. around 7pm on chandler road
i thought that r32 and the merc belongs to lindsay fox?
spotted black R33 series 2 black rims down bergins road last night around 6ish. i know your a memebr here but i forget your name lol you waved i got excited trying to find my light swtich to flash ya lol
thats me =] yeah i live around there
there is a thread for that comparo on here somewhere
last night at fountain gate shops i got a SAU VIC card put on my windscreen from CAJFLY :wave:
yeh that was me. nice clean 33 u got there. i was going into bunnings and saw it and then ran ack to the car got a card out and left it there. went into bunnings and the car was still there so i assumed u worked at bunnings.
why thanks :banana: ahhh i see, nah i dont work there, i was just buying heaps of stuff for my house :D
Spotted purple r32 GTR on Plenty Road around 9am this morning. Beeped as I drove past lol.
That was me.....lining up to get into uni. :banana:
Sorry i didn't have time to react to the beep lol i looked up and saw you go past. :D
Spotted "YAWN" R32 GTR in Carlton. Parked right next to it without realising. Strange to see two R32s in the wild.
LOL yeah I know what you mean.
My old work carpark had an exactly identical stock-looking Silver R34 GTR to mine with almost identical plates! (non-custom, first two letters same). First time I saw it I was like... wtf? why isn't my key working? :banana:
It was cool when I got a spot next to him - twin city.
    • Waaay ahead of ya....(evil laugh!!) Will show the fitment and spec details later when it isnt as rainy !
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
