spotted a champagne colored 33 on taylors rd rowville beeped and gave the thumbs up got 1 back :banana: (had sau stickers) you live in the area?
also a black 33 on Ferntree gully rd wnet past me nice ride also
black r33 had sau stickers? i was up that way just b4
Spotted a yellow 34 gt-t going down dalton rd and turned left @ shell gave it a bit of stick sounded TUFFFFFFFFF! anyone?
hey man what car do you drive?
im around the northern burbs a lot and ill keep an eye out for you
always in lalor missus and grandparents live there
spotted a yellow R34 GTT with some tyre shop stickers(company car?) on edgars road
also seeing some r33's here and there but also a stock as a rock metallic violet bluish r32 gt4 at IGA
also, who owns the white R32 GTR thats around the corner from IGA?
Edited by GTR-boy
That was me.....lining up to get into uni. :down:
Sorry i didn't have time to react to the beep lol i looked up and saw you go past. :)
hey ali were you there on the 24/2/09?
latrobe right?
my mates told me they spotted an R32 GTR in the car park and i better go have a fap before its gone but i thought they were fkn around lol..
we were the school kids that had that seminar thingy. i dnoe, i fell asleep
haha saw you lookin. thought you had your stickers on already. thats why i wasnt sure it was u
What stickers? If sau, nope I'm not a member yet (might get on my arse and join).
i thought that r32 and the merc belongs to lindsay fox?
it does!
same tow truck that dropped it off to Autosalon a few years ago when it was in our stand
i remember because i thought "what a filthy truck for a car like that" :down:
last night saw a white r34gt at fountain gate driving around near magid drive and also a dark colour r32 with sau stickers at fountain gate maccas. gave it a little bit as they were leaving the car park lol.
yeh it would of been, i was in the little car park near the food court entrance with a few mates who had like a meet and greet with the car club that they r in. i was gonnna wave as i have seen ur car b4 but then i thought better not just incase it was sum1 that wasnt friendly. lol ne way prob see u around sumtime soon ne wayz
Yeah most likely, coz you live around the corner from my mate, but i havent seen your car there in ages :down:
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
