Very nice black 32 GTR with a black 34 GTR rear wing on it near Bay St in Port Melbourne. Looks really good and havent seen that done before. :)
Hmm, interesting. That was me... Cheers :P
On that note, I always see a black r33 gtst parked on liardet st in port melb everyday. Once saw a black r34 gtr with no plates parked in the same street.
Looked tough.
Edited by GT32
Thursday
White EVO X on Greensborough Hwy at 4:15pm
my 1st Nissan GTR, Silver on the Eastern Fwy at 4:30pm, plates [KIRUY]
BMW M6 on Hoddle St at 4:40pm Plates were [bMV-10]
Friday
Silver/Bluish EVO 9 near botanical gardens
Today
Black R34 following me in my daily(White Civic) on Rosana Rd/Greensy Hwy
White S2 R33 on Greensy Hwy and a few other Skylines out and about
Only saw it for a second or two but I believe it was a Millenium Jade R34 GTR (Vspec NUR) around 2:30pm today driving along bay st in port melbourne. Everyones heads turned when it drove by. Sounded hot.
Edited by GT32
saw a nice silver r34 gtt turning onto heaths road from derrimut road today at around 12-1pm in hoppers crossing with black with red lip advan tri spokes i think. looks nice and clean. i was in the white r33.
spotted yesterday around 10:30ish blue R34 GTR parked ont he side of the road on ferntree gully road across the roads from bunnings with a white AU parked behind it and no one in the car. car looked nice and clean. too clean to be left on the side of the road.
Spotted a nice looking black R32 GTS-T at my work today at around 10:30 (Dan Murphy's Cheslea)
Also spotted the owner in the store then a cop following him inside and asked if its his skyline.
They went outside. Cop takes off its rego plates (probably expired or car wasnt registered). Bonnet was popped.
I think he got reamed hard...
pearl orangey/mustard r33 gtr dropped on black centered VSKFs in the cbd last night. porn
did have a black bonnet? saw an orange 33 gtr with black centred rims going down pasco vals road the other day with a blakc bonnet
the rims were sticking out quite wide from the standard guards/quarters to
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
