spotted 1 green r31 and green r32 with all cosmetics, kit, tinted black headlights...both looked like track cars
taking photos with fire trucks and police cars..either that or next to them at knox ozone in the car park opposite ultratune
white r32 on 'the force' (tv show)
the brainiac slashed his own tyres after it broke down so no one would steel it, and got arrested for having a foot long chef knife on his person.
:P
yellow gtt at park n wash cheltnham rd. had a chat. sorry mate forgot your name.
did you see the green R34 at ultratune on friday Beau? most prob with the same group of cars.
That was my R31 and Paladin's R32.4 - 2 of the 4 Team Ibisq Drift Cars..
We were doing a fund raiser with beaurepairs and the police and ses :P
Raised lots of cash for the SES so a very good day was had by all.
that R32.4 looks mint!
I dont see any yellow stickers??
Just saw a silver R32 GTR at the place I was picking up my bodykit from in Clayton. From memory there was a 33 out the front too.
Red R35 GTR going down Princes Hwy just then too. HOT.
And a silver R33 with stickers down the drivers door.
Far out, Callums car is finally done.
Looks amazing.
Only saw it for a second or two but I believe it was a Millenium Jade R34 GTR (Vspec NUR) around 2:30pm today driving along bay st in port melbourne. Everyones heads turned when it drove by. Sounded hot.
:P wo hoo spotted ......... although it is an M-Spec
R31 Skyline with Vic plates [ZZZ-999] Westbound on Dynon Rd, 7pm. Had aftermarket wheels with what looked like almost semi-slick compound (or just bald tires lol). Too dark and far away to see properly. Driven by middle-aged guy. Those plates are probably customised and worth more than the car lol.
    • ...just a note of warning, you shouldn't drive it about with the TCU in limp mode with only 3rd gear available ~ apart from the fact you end up sheering the ATF at the torque converter interface, the high clutch in these isn't especially the strongest, particularly bolted to the RB25DE mill...which is likely a 4AX01 box with lighter duty high clutch (the RB25DET got the bigger high clutch)...be careful out there...
    • Hoping to do similar mods to my RB20 once I get it running and reliable again
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
