ey this is my car but i thought since im in Vic i would post it up in this thread.
Whilst on here does anyone know what kind of front bumper mine is?? ive never seen it befor and really would like to know what kind it is.
Hope you all like it and can give me some infor on the type of bumper it is.
Not sure, one without front indicators? :P
the Front indicators use to be next to the big foggies but i moved it up into were the parklights use to be then changed my parklights to led strips like BLK sz has. my next move it to connect the old indicator spot up to my parklights aswell s the led strip.
Not that you asked were they are but ithought i would just let ppl know incase it does help them with figuring out what kinda bar it is:P
Haha i may not have asked, but its still interesting to know what you have done :P
lol..i think u and Cr34m were laughing at my nephew's masterpiece on my grill... :P
ROFL, i saw you once when i went past on P/hwy with a mate and i told my passenger who also has a 34, "please tell me you did not just see a 33 with a mustang badge" and he's like "no" so im like ohhh god good it must actually be a mustang!
Then i saw you at China Bar and i shat myself laughing! HAHA i was like, there has to be a reason he has that thing on...regardless of what i say, its your car man, i find it ammusing and at the same time disturbing! At least it suites the front grille nicely. Can't be worse than my green looking thing.
lol, next mod..4.0L 60 degree v6..haha..actually, i find it pretty disturbing at first...but now..kinda used to it and it brings me alot of 'new friends'..so can't be bother putting the old one back..lets just make it low..dun let Jin know or next time when i go chaddy, he will be so eager to see my ride=P... i like your green thingy there..it looks really solid and one of a kind(or maybe i shud say two of a kind)...lol
Edited by toshirokato
Spotted two black 33s in Springvale around 2:45... ...Followed one across Springvale road towards Westall Rd... ...He turned into a workshop just before Westall Rd... ...The other was going the other way to me and the first and stopped at some lights... ...Had a CarX Australia sticker across the windscreen and I think SAU stickers on the 1/4s...
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
