B/S! :banana: I spotted you like 2 weeks ago or whatever on the Ring Rd and SMS'd you 2 secs later to see if it was you :( hehe
oh yeh forgot bout that, and about a minute after u smsd me ruffels calls and spotted me as well :D
f*k me heap of lines out today, but will only mention ones i remember...
white r32 turning into sum street of keilor mountain hwy, had a stuffed front bar, but looks tuff
white r33 parked in front of super cheap water gardens, nice car aswell,
and two chicks in a black r33 cruzin past water gardens towards sydenham, they were either stoned or had sligte case of sun stroke, lol passenger was cute...
Spotted red series2 r33 gtst drive past me on napolean road, rowville (Tuesday 18/3/08)
I think it was rushs?
Drove alongside a silver r32 on boronia road, Wantirna at about 9am
Spotted white r32 drive out of Shell petrol station on Ferntree Gully/Springvale intersection.
Had QLD rego plates and SAU-VIC Sticker. Was around 3pm~
Drove alongside a silver r33 gtst on ferntree gully road at around 3:30pm.
Havent been spotted in ages :teehee:
silver R32 GTST at Hallam train station - was sitting on Hallam Belgrave Rd waiting for the boom gates to come back up
Big cooler, exhaust and stock wheels sorta polished up
Sounded pretty nice - reminded me of how much car sounded on stock turbo :P
Spotted an R34 GT-R parked on Burwood road just next to Camberwell Volkswagen yesterday morning. Can't remember the reg tho...
Edited by flyingfridge
    • Just a follow-up on this topic. From what I can tell so far the rusty residue on the engine block might be unrelated to a coolant leak or maybe just older than anticipated. After driving it from the winter garage to my friend's garage I could not see any new traces of coolant leaking there, but I will test this properly once I was able to fully warm up the car and drive it for a bit. I think I can agree that the whole porous engine block stuff is kind of nonsense, but there is just a silly amount of true, false and half-true information on anything Skyline-related on the internet.
    • hrmmm , not mine , easter plans to pull engine not happening
    • I removed the IACV, cleaned it and reinstalled.  I found a video on youtube that helped with the whole process, the guy then said the idle needed to be set, so the process was to get the vehicle up to operating temperature, unplug the TPS, set the idle screw in the IACV so the RPMs were around 600, then plug the TPS back in.  After I reinstalled the IACV, the car started (because, it was a cold start), once it warmed up, the car died, I adjusted the idle screw to see if that helped anything, it did not, I had to wait about 3-5 minutes, then the car would start back up. Only to shortly cut out, and only crank.  I loosened the TPS to see if adjusting that would do anything, and when I would rotate the sensor clockwise, there was a humming noise, but it would go away when I got the sensor in the horizontal position.  It only made the hum noise with the key on.  What do you guys think? 20250414_172604.mp4
    • Quick update.  The engine grounding strap was replaced, the engine is now happily running.  Tested the voltage drop before replacing the strap, was about 1.2ish volts down between engine to battery, chassis to battery. With the new grounding strap, pretty much no voltage drop at all.
