pulled up behind a white series 2 r33 gts-t at caltex carwash in wantirna south this arvo. driver didnt look too chatty today.
5mins later a black r32 GTR wth SAU stickers pulled into the auto wash.
also spotted that silver r33 with purple star decals down the sides leaving knox. also a member
Not so. Restrictions for p-platers don't apply on your L's. Crazy but true.
Crazy indeed. 16-18 yo's, great drivers, here, drive what you want just have someone next to you. 18-22 yo's, oh no you've lost all ability, nothing nice for you, what's that? You're off your P's, ok just joking drive whatever you want again.
was driving alongside R3DLNE on Saturday around 4pm.
Also spotted card left on my car at Supercheap Rowville. I knew I recognised you from somewhere when waiting in line haha
LOL HI
ye saw the car and i knew it was you but forgot for a min what you look like lol so ime like hmmm ill leave a card :D
now thats just fkn annoying lol
whats even more annoying is guy down the road sold his Maserati and is now driving a ferrari 599 which is parked on the street with the front wheel kissing the kerb :D
Leith i think. htial.
Yup yup... ...That was me... :)
It's an "a" and not an "e"... :rofl2: ...my forum name is my given name backwards...
spotted silver r33 with stickers all down the sides yesterday at maccas glen wav
That one wasn't me... ...Wait... ...no... ...Could have been me because I was just driving past along Springvale Rd... ...I was heading home a different way from Knox... :D
Spotted Black R34 GTT at about 4:55PM on Lonsdale and Spring St. Looked through the dark tint windows and saw a hot Asian bird. I was the guy in suit with Telstra, stripy pinkish tie and spikey hair in front of DHS. You made my day :rofl2:
Edited by theponyremark
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
