Just spotted white r33, maroon r33 and dark blue r33 all in the one carpark at swinburne uni.
Also a white r34 a grey r34 4 door in the next car park. i was in the black r34.
Swinburne seems to be like a waterhole for skylines would be cool to meet some of you guys.
Spotted 50thousand cops patrolling all the way from cooper st to reservoir station HIGH STREET KEEP OFF IT!!!!
Yeah how bad was it!! They were everywhere, especially one marked station wagon which kept doing u-turn after u-turn patrolling directly outside epping plaza. I even watched it pull over a man and his daughter on their bicycles because they weren't wearing any helmets, lol. Inside epping plaza were officers patrolling the whole joint as well. Our streets have never been safer :/
Edited by GT32
LETHAL 6 or LETHL6 some sort of number plate combo like that
Red r34 GTT, Black bonnet
i have seen it a couple of time on the great ocean road on sundays...
any1 here own this?
his username is R-SPEC or something like that...
indeed.
Daz guessing you were the silver 33?
btw bonnet is red not black ;)
haha dunno where i pulled black from then... nah i have a black R34 GTT, but most of the time when i see you i have been riding motorbikes or in a ute.. ive seen you a couple of times inbetween lorne and fairhaven i recon. you drive down there a bit do you?
if im in my car next time.. il flash lights n wave! :P i always wonder if the skylines i see are off this
yeah most sundays if weather's decent and i got nothing else on i usually drive down to the GOR with a mate or 2 or if everyone's being weak im still there either way. by far the best and most relaxing drive you can go for
ahh dont really pay attention to bikies but i see a fair few of em there usually. beep us next time you drive past :worship:
if im in my car next time.. il flash lights n wave! :D i always wonder if the skylines i see are off this
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
