usually not a fan of widebodys, but that one is clean and not over the top...only got a quick look but you could tell it'd have quality parts on it...the TE's looked the goods..
anyone got any better photos?
let me know if he ever sells Rim spec...
i dont think he'll ever sell it lol
dont have any pics of it with the TE's...
Looks like that might be one of the TE's in the garage, before it was painted black...
Actually not a big fan of the front, I only saw it from behind and then quickly on the side as I pulled up next to it, but the rear looked good
I remember this garage, that's the guy I bought Nismo 555's from lol. It is a nice S15, looked better in real life with the black wheels.
Spotted an silver R32 gts (don't think it was a gtst - just didn't sound like one) corner dalton rd and western ring road - around 11pm ish.
It was riding quite high with "mexican" offsets and a GT-R badge on the rear.
What's with so many skylines and GT-R badges lately :down:
Each to their own I suppose.
What's with so many skylines and GT-R badges lately :cool:
i'd like a gtr badge, for my gtr.
Hi :P
I didn't see you what car were you in?
I was just omw to work
I was driving my folk's red shopping trolley aka Daihatsu Charade :)
I was driving downhill towards safeway - you were driving uphill towards the hospital.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
