Saw cr33m around 2am on princes
Ya i was around him...saw you flyin past in the service lane next to shell near westal rd on prinny...sounded NICE!!!!!!!!!!!!!!! :thumbsup:
Saw vspect on Friday night on chapel.
Also saw typem twice yesterday around the Croydon area
:action-smiley-069: .... saw me driving or my car parked?
Saw BASTI too there...well he saw my car parked and then called me and then saw him drive past... :D
Saw vspect pulling on to prinny highway friday arvo i think it was.
would have been me on the way to chaddy...:P
Saw Kamikazeninja taking her car off a tow truck this morning. Is it back on the road yet?
was going away to be assessed. Eta approx 1-2 months before she's back on the road 100% better... And with a few more kws... Than she was before.
Spotted a white r34 2 door in Cambwerwell 2day around 12:30 - 1pm.
Guy driver, kinda reminded me of Tom Cruise from top gun with those sunnies.. :)
Turned out of the laneway near the Salvo's, on to Riversdale rd.
Spotted Silver R34 again out the front of sharp panel paint on highbury, i assume must work there.
See silver r33 every second day on highbury rd with a big IC, think it's the same one i see at world vision australia.
Guy always has a baseball cap on.
Yellow r34 on batesford rd camberwell/burwood, does it eva get driven????
The other day on Middleborough rd, spotted a silver s1 stag, chick driver, gave a flash of headlights, no response.
Spotted a suuuuper clean and very shiny Red R32 Coupe with Bronze look-a-like LMGT4 rims. On Wellinton Parade as I was taking the train into the city. Then AGAIN! On William Street as a was walking from Flagstaff to my work lol. *Stalk*
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
