Saw a yellow R34 coupe that had a black bonnet with number plates "GFORCE" on the way to monash uni in the city today at around 8am (on elizabeth street melbourne central), i've seen it twice so far during this week, wonder if the owner uses it to go to work or something?
Cheers man, more than happy to have a chat next time if you see me again :)
For sure. Hopefully I'll be in my 'line then :)
Yarp that was me heading to work -_-
Haha thinking back on it, it was probably monday. But eh. I was heading to uni -__-.
Yellow r34 pulled up beside me on Princes Hwy (Springvale area) Thursday around 2pm ish. Think you beeped to say hi, may have ignored you, lol; didn't realise you were a sky until you drove infront (if you're on here, sorry didn't mean to be a snob) ;p
  • 2 black 4-door r34 on my way to chaddy this arvo, about 1
  • black s15 on chaddy, parked beside me
  • on the way home from chaddy: red 300zx, silver 370z, yellow s15, red s15
  • 1 white 4-door r34 coming home from chaddy on footscray rd about 2:45pm
white r33 gtr with black te's and jap leaf symbol on the side qrter windows. Parked on Boronia/dorset rd intersction. Blacked out indicators too i think
twas me, no plates anymore :nyaanyaa:
and haha Rotas fooled ya :P
haha was thinkin it was you but why the plate change? Also no sauvic stickers?! Whats going on man haha
haha I decided to sell the plates, thinking of something else to get :)
and yeah never got sent any new SAU stickers with renewal :( havn't had them since my old non turbo!
Spotted an M35 (I think) Stagea at Bunnings Narre around 1:00 today, in black with SAU stickers. Looks bloody hot, no Stagea badging on it though. Was in my brothers car so you wouldn't have noticed me.
Also the same white V35 coupe parked in Berwick where the IGA is around 8:00 tonight, see you regularly near my shop there, would like to know who owns it, it's a great looking example.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
