Thought that was you... ...but there is another yellow 34 around here so I wasn't going to wave until I was sure it was you...
Haha, there are actually a few yellow ones around here now :(
I reckon at least 4 lol
Saw Birds this morning again. At our little intersection lol! I was driving Esther's S13. Did you see it?
Nah man, I have trouble recognising you in your car half the time lol. I "wake up" at 8:20...so I'm still in zombie mode when we cross paths half an hour later. Pretty cool how many times we both end up at that intersection though. Will have to remember to keep an eye out.
you get up at 8:20 in the morning?
Birds... you lose my vote for PM mate...
hahaha.
allways see around 4:00 p.m on Fairbank rd & Westall Rd a gunmetal R33 GTR with plates vspec, A white stagea, and sometimes see random GTR's coming out of Yiannis im assuming RE custom's, a Yellow GTT in the the black swan car park as my work places west side of the property is adjacent to the rear car park. i see so many damn imports around clayton south, im in a black r32 gtst with 32 gtr wheels on the back, dropped. its a pig haha
BLACK R33 WITH RED RIM TRIMS AT THE GRAVEL PARKING AREA IN PARKVILLE ALWAYS THERE EVERY SINGLE DAY TODAY I PARKED NEXT TO YOU! =O
A toyota supra i drove past on the eastern freeway at about 4.30pm he took this as LETS GO 120kmh and zig zag through everyone on the freeway!
Also another R33 can't remember colour on eastern freeway today too, was driving on left lane.
Last night: R32 GTR on whitehorse road/ station street boxhill parked, a silver R34 sedan on station street parked outside the restaurants.
white or silver? saw one driving past earlier today... u in ur skyline today?
it was white, yeh I was in my skyline today. I know the car because it is always parked in that 3 hour zone near the train station in that fenced off area.
Could have been me since I was on the eastern 3 times yesterday. But then again there are a lot of R33s on there.
yeh it was you haha i remember it was a white r33 =D did u see the supra?
Were you headding in the opposite direction? I think I might have seen you.
Also what time was it?
Edited by Dylaan
it was around about 4.15-4.25pm outbound i was driving next to the far right lane u were on the left/next to far left lane same direction
Edited by Grey
    • All the schemas I can see, indicate your typical setup of ATF 'cooler' (read: heat exchanger) in the bottom radiator tank..ie; https://nissan.epc-data.com/stagea/wgnc34/5413-rb25det/engine/214/ ...but I can prattle on a bit here. These trannies have a thermistor in the sump ~ the TCU reads this and 1. bumps the line pressure up when the ATF is 'cold' and 2. prevents the TC lockup clutch from operating, until the ATF comes up to minimum operating temp (keeps the ATF 'churning' through the TC so it heats up quicker) -- trigger point is around 55C. In these conditions, the engine coolant temperature rises faster than the ATF temperature, and also helps heat the ATF up, which is why it's best to think of the in radiator tank setup as a heat exchanger ; the heat can flow in both directions... ...with these trannies, the 'hot' ATF comes out the front banjo bolt, flows through the cooler/heat exchanger, and returns to the box  via the rear banjo bolt. This gets a mention, due to the wildly different opinions wrt running auto trans fluid coolers ~ do you bypass the in radiator tank altogether, or put the cooler inline with the in radiator tank system...and then, do you put the additional cooler before of after the in radiator tank system?... ....fact is the nominal engine operating temp (roughly 75C), happens to be the ideal temperature for the ATF used in these trannies as well (no surprises there), so for the in radiator tank system to actually 'cool' the ATF, the ATF temp has to be hotter than that...lets say 100C -- you've got 25C of 'excess' heat, (slowly) pumping into the 75C coolant. This part of the equation changes drastically, when you've got 100C ATF flowing through an air cooled radiator ; you can move a lot more excess heat, faster ~ it is possible to cool the ATF 'too much' as it were...(climate matters a lot)... ...in an 'ideal' setup, what you're really trying to control here, is flash heating of the ATF, primarily produced by the TC interface. In a perfect world, wrt auto trans oil cooling, you want a dedicated trans cooler with builtin thermostatic valving - they exist. These should be run inline and before the in radiator tank system ~ when 'cold' the valving bypasses the fin stack, allowing the ATF to flow direct to the in radiator tank heat exchanger, so it works 'as intended' with helping heat the ATF up. When 'hot' (iirc it was 50C threshold), the valving shuts forcing the ATF through the cooler fin stack, and onto the in radiator tank heat exchanger...and you sort of think of it as a 'thermal conditioner' of sorts...ie; if you did cool your ATF down to 65C, the coolant will add a little heat, otherwise it works as intended... ...the 'hot' ATF coming from the front bango bolt, is instantiated from the TC when in use, so all/any flash heated oil, flows to the fluid-to-air cooler first, and because of the greater heat differential, you can get rid of this heat fast. Just how big (BTU/h) this cooler needs to be to effectively dissipate this TC flash heat, is the charm...too many variables to discuss here, but I just wanted to point out the nitty-gritty of automatic trans fluid coolers ~ they're a different beastie to what most ppl think of when considering an 'oil cooler'... /3.5cents
    • Been a busy but productive day. Axle and hubs acquired. All fitted up after a bit of modifying. Need to sort out wider mudguards and running light reflector covers but other than that the trailer is gooood to go !!
    • Selling a SMIC for a Nissan Stagea C34 Series 2 and the pipe from the intercooler to inlet. (I believe it is the same R34 GTT, please correct me if I'm wrong) Price: $50? I dont have a photo of the big black pipe that goes from SMIC outlet to throttle body.
    • So the original radiator is leaking now. Looking at getting a fully aluminium one next. Am I correct in saying that the Series 2 Auto Stageas have a separate trans cooler from factory (located in between the rad and intercooler in my previous post/message).   Currently looking at Fenix $460, Blitz $700, GReddy $800, and KoyoRad $740. What are everyones thought on Fenix ( ive read a few comments saying theyre cheap Chinese rebrands etc and how their build quality is... well.. chinese...)  compared to the others? Worth the extra couple hundies?
