Spotted Thread
paulr33
must've been there bright n early haha
i found a parking spot out the front, and there was a silver 32R that was behind me, but i got it first.
when i got out, i realised if i had moved closer to the r34 in front, he probably could have JUST fit. sorry dude
was the r34 white 4 door because that was me and dont worry i didnt have trouble getting out
Just spotted so many skylines.
- Black 34 Gt -t parked opposite me at cheltenham shops
- Black 32 Gtr with 34 rims, passing me walking through the station alleyway. plates were 'jet' something..
Both looked amazing and loved the DIY front lip on the 34 matching my own :)
Seen that Jet R32 before,
Spotted just before at about 2:35 a fkcing awesome R34 GTR (Silver) cruising along beach road st.kilda, Looked like Goran's car... mate, if it's you... what a MACHINE!!! looks amazing!
LOL that was me , was thinking that aswell then i quickly did another lap but there was no room . All good , got a spot out the back whistling.gif
Just spotted the same R32 just then. Plates are JET-26. Looks so nice!
Spotted a white 33 gts p-plater in Main St, Croydon this arvo. Had black te37 replicas(?) probs the rota ones.
Also a big sticker on the boot saying "Spoon Sports". You realize Spoon is the Honda tuning company yeah? The sticker you're after is Nismo :thumbsup:
ROFL
Yeah that was me. Was on my way home from Chelt.
Saw the MR2 coming down the street I was thinking that was you and it turned out it was! Looked f#@ken clean man love the color.
Haha thanks man. Shame you saw it in such terrible condition (filthy and smashed front bar). It's normally very shiny and detailed, I promise :P
Have you had a respray? Your paint is like glass.
Spotted this morning:
White R33 GTS-T on Greens Rd. Had SAU stickers.
Also spotted Harsh today on South Gippsland Hwy.
:banana: finally got spotted....were you in your car?..damb i must have been blind not to see that sexy painted MR2 :P
Bloody curry :P
SHIK AS CURRY!!!! :nyaanyaa:
:worship: finally someone else thinks that same...
Nah, was in a blue stock-body MR2. Doesn't really stand out at all so can't blame you for not seeing me :P
Yeah i know the feeling been a while since i washed mine as well.
The entire front of the car has been re-sprayed so when i do wash and polish it it does come out like glass.
    • Oh also, looks like it will be 3-4 weeks before they arrive - so no coolant change until then 😕
    • @soviet_merlin Managed to find my part and get it off Amayama. While I was at it and paying 9.75 AUD shipping for a $1 piece, I thought I may as well get some other plastic clips I broke 🙈  Thanks a lot for this link
    • The point of all that for me was to get to the PDM (yes, v37 is as fancy as a haltech) which is between the battery and the front inner guard.  In there, pins 80 and 81 on connector E125 are for hi beam according to the USDM manuals. I chose to intercept the high beam signal there as it is next to the battery and firewall so it is a good place to mount the fuse/relay for the LEDs. Unfortunately because you can't access the PDM with the battery in the car, it is difficult to test those wires are correct. The fuses for Left and Right high beam are marked on the PDM cover, so I checked continuity from the fuses to those pins with a multimeter, and it seems to be right. From here I need to splice a wire into one of those 2, and run it into the cabin for a switch, then run the trigger wire back to that general location for the relay. So, I removed the driver's side guard liner to check out where the wiring leaves the engine bay and enters the cabin.  Turns out, that does not happen behind in guard liner at all....waste of time, nothing is routed through there, so that was another 5 pin clips, 4 screws and a bolt of wasted effort All of the wiring is actually run across the separate compartment between the engine bay and the cabin under the cowling...so off with the windscreen wipers after all....
    • So....the good news is you don't have to remove the windscreen wipers to replace the 12v battery in a v37 (just). You do however have to remove: 1. Battery area cover (un clips) 2. Battery area trim (pin clips) 3. Nav side windscreen cowling (more pin clips, plus the trim between the cowling and the front guard, and half of the cowling to bonnet seal All of that gets you to here, with clear access to the battery While there, it is worth clearing out the leaves and dirt that run from the cowling into that well, my car had a lot of crap there and it is a guaranteed future rust hotspot
    • Onto trickier matters....this time of year a LED light bar makes a massive difference to avoid skippies etc, so that was the first main priority. Unfortunately unlike both the Cima and the Fuga, there is no chance for a large central light bar inside the grille due to all of the redsport bits already there (intercooler radiator, extra water pump, sonar stuff). So this time I've gone a pair of 8" light bars which does have the benefit that they can be angled outwards a little as well. First, bumper needs to come off as there is no way to access the space behind the grill with it in place. Unlike the R32 which is (now) held on with 2 screws, the v37 had about 30 pin clips, 20 bolts and also 6 clips holding the damn thing on. Basically you remove the intake (clips), the top side covers (nasty clips) to get at 2 bolts, the front of the undertray (about 15 bolts and 3 clips), the front side inner guard covers (3 bolts and a couple of clips each) to get at the bolts at the rear of the bump in the wheel well, and then 3 clips near the headlight (outside, then under headlight, then above headlight) As part of that process the car got its first "race" mod so you can get at the top bumper bolts without removing the trim. There are also about 8 different electrical connectors which are in grave danger of being cut and replaced by one multi pin deutsch connector one day. On the bright side it is clear the bumper had never been off by how tight the connectors were. Once off, you can see there is very little space to work with. The lower section was not an option as the angle to the road would suck, plus the sonar module would push everything too far to the centre So I mounted the left side bracket to just clear the water pump (a miss is as good as a mile, they say) and the horn has been moved backwards too. The brackets on these Narva lights were a nice height to clear the front reo, and I just drilled and rivnut-ed into the reo (angle drills suck, but at least it made the job possible) With both mounted Minor adjustments to horn locations but everything else cleared. Those horns may well get moved / one deleted depending on how the cooling is on hot days, they were moved well to the side in the R32 Next, onto the wiring which will be a pain...
