saw a red p plate girl driving a black r34 gt coupe, had a chrome cannon exhaust and rims, sounded auto. I did a flutter past her window to show how it should be done :P was on Burwood hwy yesterday near cathies lane
parked next to a black r34 (red p's) in level 1 eng carpark yet again.
also saw a white r33 gtst, a grey s1 r33, black r34 gtt, and r31 all on the (second top?) level of cinema parking at knox around 5pm LOL. with my car, at least 5 skylines on that level alone XD
saw horrible bosses...
"so why were you doing 65 in a 25 zone?"
-"...i was drag racing. i'm a drag racer"
"in a prius?"
"i don't win a lot"
:D
Spotted a burgundy r33 and another car all smashed up in the middle of burwood hwy (by f/tree gully red rooster) at about 2:30pm today. Cops + fire engine on the scene. Hope the drivers are ok.
i saw pics.
its pink!
alvin- selling the soarer?
Nope.
I wanna see!
Its not pink, mohomo lied.
it is however, suv spec, its stock everything! car's for my dad. i'll be putting up the pictures in awhile. be patient.while i go fry up some chicken wings for now.
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
    • I just finished up a manual swap and I have a 1999 S2 AWD automatic in my garage, depending on where you are located. I'm in the the midwest of the US.
    • I’ve heard it can be done, you need to redrill the holes where they bolt to the chassis and apart from that they are the same. I’ve never done it or know anyone personally that has, it’s just something I’ve heard
