keep seeing a purple 33 gtr on dandenong hastings road heading south, think it has bronze/gold wheels.
its either really dark purple or black.....
Edited by Plattsy
Spotted you car once again...same spot same time...
then heard you needed new breaks ? damn dude!
LOL.. nah. it only squeals when cold!
for like 5 secs. silly nissan caliper design, apparently needs more grease on the retaining pins.. not that it affects me, started with the new rear pads.. was worse 3months ago.. they're way better.
no more rbpowa stagea yeah?
oh lol well it must be! ive seen one other red r33 s2 around but it had silver wheels unless it was the same one and changed wheels or the sun impaired my vision!
Yeah I've seen another red 33 S2 with stock silver wheels on it, I think he was as amazed as I was cos he was like :O as I drove past, then waved!
Eltham local? Noice car! Grew up in Eltham..... Monty and now Kangaroo Ground. I have a white R32 GTR Vspec and Dad drives a white Focus RS around too. Will be good to say Gday.
Wash your Car!!!! It's filthy today.
Nice, I think I've seen the Focus around a few times.
I know, I know.. haven't washed her in ages :(
    • Maybe but doubt it, when I jacked it up it was creaking in the j arm again. The inners are all good, I inspected them. Remember that also it did fix the problem but temporarily.
    • Could be the other bushes. The inners.
    • Once you lose the adjustable bushes, you have almost no adjustment at the front for anything that matters. You can only wind so master caster at the front, and ~7° is fine. You won't have choice of front camber. If you only have rear camber arms (ie, do not also have adjustable upper tension arms), you shouldn't change their length very much, because you will introduce bump steer. And, you will struggle to find a workshop that will be capable of doing all the adjustment work necessary to simultaneously achieve a decent rear camber number, get the toe right, and minimise bump steer. I would guess there's probably 8 hours of work there. So, stockish rear camber is fine. Although, keep in mind, that stock camber, by number value, does not mean stock arm length when the car is lowered. You will need to lengthen the RUCA to get back to stockish values and that will require the tension arm to be lengthened a little also. Without any other guidance, any change made to the RUCA should have the 2/3 of the same change made on the tension arm. But that is only a rough rule of thumb and the relationship might not remain linear across a wide range of adjustments. And it might not also be as close to minimum bump steer as you could achieve if you did the bump steer measurement and adjustment properly.
    • Well it does have a motor with the same DNA as an Accord V6 motor. The J30A is a successor to the Tiger rice cooker C32A motor found in those cars.
    • FD RX7 I would probably marry if legal R32 GTR is toughest NSX looks like it's made from leftover Prelude and Accord bits
