Spoted a white R34 behind infront of a black 180, i was the burgany red Ford au, this was at the hallam KFc/ Hungryjacks lolz was in dads car me and gf was going to drive inns to see the pinapple express lol funny film but i would only see it once lolz, didint go in my R32 still has the jap headunit still saveing up more cash for headunit lolz
Spotted Basti at the corner of Springvale road and... ...umm... ...That other one... ;)
Dude... ...that P plater in the PT kept dogging me all the way down the extension...
Also spotted a yellow 32 GT-R on Westal between Center and Princess...
And around 5 a dark grey 33 on Glenferry Rd... ...Was packed into traffic... ...almost turned two 33s into one when he decided to pull into a park... ...lucky for me there was no oncoming... :)
  Lauz_90 said:
Spotted a white R34 GTS with black nismo wheels (??) on Ground Floor of Crown carpark... parked in the same place everytime i see it!
Very clean :worship:
Hate to sound like a worry wart though if someone said this about my car I would be a little concerned.
Fair enough to spot it but the comment about being there all the time is little concerning with amount of cars going missing these days.
Not having a go at you just think this could be edited.
Security parking or not.
On a lighter note, spotted purple GTR33 on green gully rd/sunshine ave 9:30pm tonight
    • I removed the head expecting to find broken and bent valves, but instead found number 1 at TDC and cylinder 2 at the top of its cylinder stroke as well, thought that was weird and proceeded to push cylinder 2 back down until it either bottomed out on its other piston half or the conrod either way we found the issue kind of,  now to remove the engine and see how the block looks, hopefully its just the top off a piston.
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
    • FYP. Sadly. Even bolt cutters wouldn't take 2 sec. But in the days of 18v angle grinders, nothing is safe.
    • One piece driveshaft I would recommend a dual CV setup otherwise stick to OEM. I have heard most one piece driveshafts cause excess vibration otherwise. The transmission grind I'm quite familiar with. You can try shockproof gear oil, otherwise you need a new transmission. The shifter is extremely simple on these cars. If you want pull apart the assembly and replace the plastic bushing but I doubt that fixes anything. The tail light issue is very common, unfortunately new tail lights are long discontinued. The trunk antenna going up always is because your radio doesn't have a true power antenna control, just remote amp power signal. There is a blank switch plate that you can pop out and install a switch for this or alternatively source a head unit that has proper antenna control. Throttle body sticking you have to disambiguate by disconnecting the cable and seeing if the linkages are the problem or something else. There is a procedure to adjust them, refreshing them is also somewhat involved if that's the issue. I have dealt with many of these issues. Old cars really are fractals of problems. The more you fix the more you discover there is to fix.
    • Welp, you've got a long list of experiences right there. I'd say you're on the right path.
