saw a black r32 on stud rd heading towards rowville from dandy way wif a canary on the windscreen and a white sticker at the top of the back window (car looks nice). as i was coming out of the service lane in between Brady rd and dandenong creek.
spotted a silver 32 stockish with big mutli 5 spoke rims cooler? and i think a nismo sticker on the back bumper
i cut in front of u, sorry if your on here for cutting in front of you i didnt relise the line to tirn right was so long
Edited by tin-pain
silver r33 with p-plates leaving fountain gate carpark last nite.. tried to spark up a bit of fun when i was in the lane next to him but he didnt wanna play =P
Silver R33 you said?
Did it by any chance have 19" 5-spoke chrome rims and a "Decepticon" sticker on a prime coloured bonnet?
Spotted a number of 32s and 33s today...
Stand out was a silver 33 on princess that turned left towards Caulfield Uni and then right and the roundabout into the uni...
Plates TVSxxx... ...and had RE and SAU stickers on the quarters...
Yeah that was me. Had to grab a text book from the bookshop. :P
Spotted James in the Pink Panther on Park St, South Melb tonight soon after 6pm.
Grey 33GTST S2 a little further up near the roundabout on Park St
M5 in black with a space saver so no top speed runs there!
spotted a white r33 gtst with SAU sticker on warrigal road yesterday and was driving behind it at about 12pm, number plate was something like TIL-xxx.
spotted a bayside blue r34 gtr? with the plate "VSPEC" on cheltenham road at about 6pm, and a white r33 on lower dandenong road with plate "RSPEC"
Edited by Charles89
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
