lately my car has been jerking back n forth between 1000 and 3000rpm and is getting annoying...
it only happens on the low revs, as when the boost kicks in it pretty much goes away...its a r32 with rb20det....
no mods other then r33 turbo, front mount, exhaust, safc...10psi boost....just began doing it lately n wasnt always like that!!!
GOT ANY IDEA'S????
THE IGNITOR PLUG WAS LOOSE AND WAS MAKING RIDE ROUGH AND AS THOUGH IT WAS RUNNING ON LESS CYLINDERS....
FIXED NOW...BUT ON IDLE REVS SEEM LIKE THERE MISSING...GOT ANY IDEA'S??
Edited by allthewaytotheskyline
what does your car idle at? does it idle high every now and then? does it only do this when car is idleing high?
my car does it when ideling high, it idles high when the wheather is colder, best take it to a mechanic as thats what i will have to do.
i suspect in my case it could be my TPS or CAS, because i have already eliminated the AAC by cleaning it.
probably try cleaning AAC see if it fixes the problem.
I am having a similar problem as well, after it has been driven around for a little while. It starting to get worse, started off as a intermittent problem. If I hold my foot on break and put a little load on it at 2000 rpm while driving, I can feel it surging. I was on the pathway of a sensor as well.
Please Read my blog.
http://www.skylinesaustralia.com/forums/blog/whitebeast/index.php?
Edited by WHITEBEAST
  • 1 month later...
i was fiddling with the coil packs and unplugging them 1 by 1 and seeing which was supposidly faulty...then when i fiddle with the ignitor i realised the plug was slightly unclipped...so i pushed it in tight n hopped in n bobs ur uncle...all good
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
    • Sorry, I wasn't very clear.....just that the standard injectors are apparently good over 600rwhp/450rwkw which you won't get to on standard turbos anyway.....they are much better sized from factory than we are used to in RBs.
