Running 12lb boost, LT12 computer - just over 303hp at the wheels !! ;) I am very happy with that.
It is a GTS-t. My mechanic installed an air temp sensor today and change the adjustable cam gear. Went from 264.3rwhp to 303.1 rwhp with just those changes.
It is idling a bit high though. Do the new microtechs cause the car to idle higher than the stock computer? I am idling at about 1000->1200rpm !! I am going to speak to bloke tomorrow.
https://www.sau.com.au/forums/topic/21055-just-had-my-r33-dynod-today/
I am currently running a 500hp Garret Ball raced Turbo. (but at only 12lb boost)
The only other mods I have are...
Large Front Mount intercooler
LT12 Microtech
Variable cam gear
descent exhaust (but nothing spectacular)
custom dump pipe
Iridium sparks
carbon clean (everyone who gets a carbon clean gains about 5rwkw)
good tune !
Hmm, that turbo's just a tad bigger than mine. The biggest difference between your car and mine is the ECU and the cam gear. I think the cam gear has to be the next mod for mine because I can't afford a new ECU :)
carbon clean? where can you get one of these guys done!? :)
yeah, boost is what its ALL about....and cam gears too..hrm! i think im doing okay for the mods i have then.
186rwkw
powerfc
apexi avcr @ 1bar
full exhaust
front mount
stocky turbo...
next mods will be fuel pump, clutch & turbo of some description!
I place in Toowoomba has a carbon clean.
My mates '86 Brock Commodore got 5rwkw. Another guy's skyline got 6rwkw. I don't know what I got as mine was done when I got the new turbo/sparks etc.
186rwkw if pretty damn good for those mods. Youy must have a good tuner as well.
Nice results gjb977 !!
Tell me more about this Carbon Clean..
Whats it do?
Where does it go?
How much does it cost?
What does an Ex Cam Gear cost to be installed and tuned (roughly) ? They are quite a cheap mod it seems:
Apexi: $142
HKS: $153
OS Giken: $293
Tomei: $199
Trust: $171
I love these cheap mods with slight power increases, the type of mods that many people skip and jump straight in for the big turbo's etc. (JimX maybe we could order 2 cam gears and have em installed/tuned at the same time/place)
I'm currently at 272 rwhp and confident that with some small mods ($$) I can crack 280 rwhp from my basic setup.
Hey Frankie not bad power for the mods you have :)
I'll get the info re the carbon clean from my mechanic (more like an engineers workshop) and post the info tomorrow. All I know is the solution so that expensive he keeps it in a safe.
He's done so many qick cars it's not funny. (including a 9.6sec Cortina) (mainly does commodores though)
he made the adj cam gear out of my stock gear. (only had one done) - this is alot cheaper than buying 'name' brand ones.
Interesting... do you know the costs involved to get this done?
The HKS has come down in price by 25% in the last 3mths which I have had my eye on and is looking pretty nice at this stage (both price wise and physically looking).
did ur power fc have much to do with the power??
cos i am looking at getting mine on the dino, with a 12psi full exhaust, front mount and cold air on its way..
but i was looking at a power fc, are they the way to go or not??
cheers
this is a before and after. only difference being boost was raised from say 0.7bar to 1.0bar.
its hard to say what difference the powerfc made on top of the boost gain, but when I first installed the FC i remember the torque was raised like 50newtons across the whole rev range.
the car definately felt alot more torquey down low. up top there wasn't that much difference, maybe just under 10rwkw gain?
but it all comes down to the tuner. its hard to go past the FC because of its plug & play features and sydney workshops/tuners are getting alot better at them now (c&v for instance). so there'll be an abundance of knowledge around...
I'm not quite sure the difference between your car and benm's but shouldn't you be getting more the same kw's as benm. You are nice and lean so what do you think the diiference is as the HPI R34 has also 1 bar and 202rwkw's, i ask as i am about to get my car tuned and expect to get nealy 200rwkw?
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
