My car starts fine and it drives fine.
but whenever it feels like it, the car just cuts out.
It stalls while I'm driving, but im able to start the engine after about a minute with no problems.
only for the problem to happen at any given time again. :thumbsup:
any ideas what this might be? :D
https://www.sau.com.au/forums/topic/210576-r32-gtst-keeps-cutting-out/
Had the same problem in a MR2 I used to have. The car would start and drive fine, and then after a while of driving the car would just die and wouldn't start again for a few mins. It turned out to be the fuel pump, after the car was running for a while it would overheat and just shut down. After it sat for a bit and cooled down it would start working again. Next time it happens see if the pump is priming when you turn the ignition on. Just a thought, easy to check once it happens again.
