Anyone have any overheating issues with their car on these past few days? Mine never had this problem before until a few days ago, my water temp gauge rose to 2/3 of the gauge when it's usually in the middle. So I had to turn off my A/C so that the tempreture can drop back to normal.
I thought my water pump or thermostat was failing since it has never happened in the last 3 years of owning it. But this happened to a friend of mine too so I wasn't sure if it's just the heat or something wrong with my car.
If this is uncommon, then I will take the car out to the mechanic to check. The coolant in my radiator is still full so that wasn't the problem I think.
https://www.sau.com.au/forums/topic/210583-over-heating-issues/
Also be sure to check your radiator fan for issues, I think thats the source of my overheating issue.
One way to check is get a friend to start the car when its pretty warm. Hold the fan gently, with a finger or similar, do not misinterpret this post to mean shove your hand straight into the fan and see what happens.
If the fan try's to turn with some force then its working.
If its like mine you can hold it with one finger and even after you let it go it takes a while to start spinning again.
Oh, and if you injure yourself by doing this I take no responsibility whatsoever :).
Edited by some_cs_student
One way to check is get a friend to start the car when its pretty warm. Hold the fan.
I prob wouldn't recommend stickin your hand in there and cranking the car.....
You can use something else, for Christs sake don't use your hand lol.
lol, the fans not that hard to hold still when you start the engine, the coupling just slips the same as when the engine is revving which is what keeps the fan at a fairly constant speed. I wouldn't go putting my hand in there when it's already spinning but otherwise.....
I get my coolant changed once a year, just before summer. If you changed yours 30,000km ago, maybe try a full flush. Always best to start simple. Also get a pressure test done on the system to see if you have any leaks and if you have time pull off your front bar and clean up leaves/crap that's infront of your radiator.
If that doesn't fix it, I'd be looking at the thermostat (replace) or maybe a clogged radiator (flush/rod).
lol man do NOT stick your hand in ther
dumbest idea ever
I've done it on 2 different cars, and I'm fine.
I don't mean put your entire hand into the fan, I mean touch the end of the fan blade and start it, if it pulls away from you then its working.
Of course if you're stupid enough to put your entire hand in there then you've misinterpreted my advice.
Also see if its spins after you turn the engine off after its warmed up, my fan spins for a long time...
Oh, and if you injure yourself by doing this I take no responsibility whatsoever :P.
LOL... ...try sticking your dick in there... *clacka clacka clack* ;)
LOL... Well.. you guys can try sticking your dick in there if you want.. but I used a branch and tried to put it in slowly.
It smacked my stick away so I'm assuming that my fan is still strong and it feels like its blowing hard.
Maybe I will try a flush first and see how it goes from there.
Did you put the branch in while its spinning?
Or did you try putting the stick on it when you started it? If it pushes the stick out from idle when it starts moving then your fine, just don't drop the stick into the fan. lol.
Good luck with fixing the issue.
you gotta put in fact as well that the jap cars such as skylines werent made for Australian weather also, mechanic told me that one time and that could be one reason for it as well some one correct me if im wrong.
Japanese weather does not hit these one off hot days, but it does get very hot and humid for weeks at a time... That is why Japanese cars have much better cooling systems and air conditioners than Euro cars of the same age.... Most of us own cars that are over 10 years old, you have to expect them to get a bit upset when it gets hot...
Citroen CX aircon was so weak, that for Japanese and Australian markers, twin air conditionsers were fitted.... They added another one in the boot... It is also once of the reasons that the Commodore grew away from the Opel versions they were based on from the VL. Holden needed more space for the larger Aus spec air con units.
    • Appreciate the feedback. It is street car, but not a daily. Last week I got a quote from a good exhaust shop for a decat, one which is bolt-on, bolt-off to be easily replaceable. I got quoted for around €150. I usually do push the motor, but I wasn't in this case to make sure that no damage is done until I get the cat sorted. I think it's best to also ask the exhaust shop for the other option and see what they can do. If (big if) I were to decat though, would it be best to tune the car or would the stock ECU handle it? As far as I know, the stock ECU is not tunable and that would require additional purchases.
    • As above, definitely bash it or get it replaced with a high flow unit.
    • get some flares on them, or wider guards haha
    • Another question sorry, what stainless do u use in the turbo external WG plumb back piping? Is it 321, 316 or 304?
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
