Wire run for front door splits
Guest barneyrubble
How do i feed my own wire into the front doors for splits without taking off the doors.
I want to run an amp to the front, and bar that pissy little factory wire.
Has anyone done it? There seems to be no space on the end of the door at all even to fit a drill if it did come to that as much as i don't want to.
By the way its an R33
If you could post some pics id appreciate it.
https://www.sau.com.au/forums/topic/2106-wire-run-for-front-door-splits/
The door wiring looms go into the cabin via a plug/socket assembly on the cabin side. Undo the single bolt with a wrench (size 10). You can do this without having to take the door off. Once the bolt is loose, unplug the wiring loom. Take off the door trim and push the wiring loom into the door and pull it out from the side. The socket on the cabin's side can be unclipped and pushed in. You can pull it out after you take off the kick panel.
The plug and socket have quite a few empty spaces where you can put in additional pins to run additional wires. Alternatively, if you only want to replace the original speaker wires, no additional pins are needed. Just find out which wires are for the speaker and take the corresonding pins out and connect thicker wires. No drilling is required.
I had to do this when I installed a door lock actuator in the driver's door in order to use the keyless entry function of my alarm.
Good luck.
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
    • I was just going to say that it's good to see you picking up the pace again. Hope the surgery goes well. More downtime just means more time to come up with new ways of digging a deeper rabbithole
