Meet N Greet Before Easter
eMsta
 Share
  • Replies 171
Posted Images
I wouldn't mind tagging along to this since i don't have work on fri :blink:
Would there be alot of police troubles at that area?. As the last time i was there for that 'big boys toys' thingo...there was a defect station set up. :thumbsup:
This meet place is not at Chadstone shopping centre itself. It is further down the road in a park park solely for the Harvey Norman store there which will be closed at the time of meet. I know the night you were refering too. This is not a major event that will attract the same attention as that night. We shouldnt have issues as long as noone "misbehaves" and draws in attention to us. Plus we wont be there the whole night. We will be moving for food and photos.
yep - 8.30 pm - i might wash the car before hand too - but at my usual place on springy road (opposite century city)
and yes - as long as there arent people misbehaving - we will be fine
and as for duck - i got an email that perhaps some of you might want to look at - turns you away from Rock Kung Restaurant :thumbsup:
lol you bringing the rolla down?
LOL hahah yeah I am! I'll try and see if I can take out the 32 though. There will be 3 four door 32's on the night if I can. Highly doubt it though. :)
haha try to bring it - I might bring mine out but but hesitant due to cops
Shouldn't be a problem man, there will be 10+? cars coming on the night, chances are they'll pull someone elses car over instead of yours. I wanna check out your car!
I'm in a pretty tight position if I take out the 32 as well. Cops pull me over and then BAM 3 demerit points gone. :)
mate im in the same position. only i've already lost 3. so BAM licence gone
bahaha yeah
maybe if I get my ECV hooked back up tomorrow night and tidy up the vac lines I might bust it out for a bit - I'd only come to the car wash though
mmm might come along actually
bahaha yeah
the fronts high but, I had to raise it so I could actually drive it - now I'm embarrassed to drive it lol
bahaha yeah
ahahaha, I wouldn't be embarrassed driving a car like that, chances are people won't even notice the height. Bring a c-spanner on the night and we'll lower it a bit more before taking photos. :yes:
My car's low as again, I lowered it a bit more over the week end. So now they're 8kg/mm up front, but as low as they were in the photos I showed you a couple months back. :)
So you're not allowed to drive turbo? Or is this under the other law how you're not supposed to drive a car more than 125kw/tonne?
I'm assuming the old rule though. Bad luck. :)
I swear Easter is in April but Im not complaining LOL!
This sounds good!
Special LILKAAAY!
You get ya car buddies and girls down there too!!! :)
yeah gonna come down with alex and tim again.. My gfs want to see the easter bunny =]
Mine is like a Skyline truck anyway, so yours will look like its sitting on the ground compared to mine.
:P
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
