Hey,
I got my R33 GTR tuned recently, I went from a Japanese Mines ECU to a PowerFC + adjustable cam gears and the boost was upped to about 1 bar.
Stock turbo's, aftermarket radiator, high flow cat, 3inch turbo-back exhaust (HKS Super dragger), stock airbox with highflow panel filter and hot weather (30degrees plus unless the workshop had air conditioning :)).
I believe those are the only performance related mods my car has.
So is this a good tune? I was thoroughly impressed with the power and the response.
Regards,
Gareth
Looks fairly spot on.
If you had a wide band on it, plus liked to tinker, it could be 2-5 points leaner. (EDIT: by this, I'm not saying its not a good tune; its a great 'safe' tune for a customer. I'm saying if it was mine, or somone that can see live AFR's, then I'd run it closer to the edge, and be wary after filling up / Summer / towing a boat)
What you have is pretty safe.
Rem, your graph shows a WOT power run, so doesn't show other 'day to day' load cell results.
Edited by GeeTR
really? A:F ratio looks a bit rough, still good but could be a bit better?
PS - *my limited experience denotes my opinion means little*
Its the graph power curve thats important.
As long as the AFR's are safe, it doesnt matter if they jump around a little bit to achieve a brilliant curve like that :(
What would you prefer, slavishly tuning to a predetermined A/F ratio? And getting a rough power curve as a result? Or tuning for a smooth and progressive power curve and letting the A/F ratios fall wherever is best for power?
I know what I would choose.
Cheers
Gary
Is that RWKW??
Did you have a base figure? Curious as i want to do similar mods on my 33 GTR. Also what dumps and front pipe you running. Cheers Nick
RWKW, its not amazing power for a GTR, but I'm thoroughly impressed by the response of the car, and its only running stock turbo's in the end.
I am unsure about the front pipe, its a HKS super dragger muffler, 3inch exhaust system, it *might* be turbo back but I'm not sure.
The car has very few engine related mods, its all suspension and cooling mods...
Better get yourself some new Turbo's......
Pushing those figures it won't be long before the exhaust wheels go.
Could have saved a bit for Turbo's first then Powerfc with tune.
This was tuned by a trusted tuner, I didn't say "push the boost to 1 bar", he decided to put it there and I'm sure it will be fine, I have locked the boost controller so it won't accidentally get turned beyond 1 bar.
1bar is somewhere between 14 and 15 psi...? doesnt sound too high? I have the following to go on my 260RS -
3" exhaust inc front pipe and high flow cat, 600x300x100 fmic, apexi PFC, K&N panel filter in standard box. Running 1 bar i should see similar? are our setups fairly similar then?
Its running 1bar.
Perfectly fine for good condition GTR items, not a lot fail.
Its only those who push harder that see issues
Plenty of 1-bar GTR's around
Yes..correct Ash. I am all for what you are saying.
Assuming.....A 100% history of the car is available..and the Turbo's have not seen more than 100K of service.
Lets face it ceramic /exhaust wheels are not the most reliable things to have stuck on a 250KW GTR even RW.
some_cs_student
The tune you have is great...and the quality work your tuner has done for many on here is un-questionable.
I was just trying to say that if I had a GTR33 "Which I have" and it still ran stock Turbo's "Which you are",
this is one of the first recommendations I would have suggested before your tune.
My advice to you still stands.
Change your Turbo's :)
I have a stock intercooler, but similar mods performance wise. Drop me a PM when you get it tuned, I'm curious as to how you will go :)
Change your Turbo's :P
Point taken mate, I will do it *one* day, need to save up more $$$ first, and then I'll worry about going for aftermarket turbo's or high flowing them or similar.
The next concern would be with different turbo's, engine rebuild :D
Anyway, appreciate the advice :)
Gareth
I have a stock intercooler, but similar mods performance wise. Drop me a PM when you get it tuned, I'm curious as to how you will go :/
Will let you know. Hoping for 220 or so, but we'll see.
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
