Hey,
I got my R33 GTR tuned recently, I went from a Japanese Mines ECU to a PowerFC + adjustable cam gears and the boost was upped to about 1 bar.
Stock turbo's, aftermarket radiator, high flow cat, 3inch turbo-back exhaust (HKS Super dragger), stock airbox with highflow panel filter and hot weather (30degrees plus unless the workshop had air conditioning :)).
I believe those are the only performance related mods my car has.
So is this a good tune? I was thoroughly impressed with the power and the response.
Regards,
Gareth
Looks fairly spot on.
If you had a wide band on it, plus liked to tinker, it could be 2-5 points leaner. (EDIT: by this, I'm not saying its not a good tune; its a great 'safe' tune for a customer. I'm saying if it was mine, or somone that can see live AFR's, then I'd run it closer to the edge, and be wary after filling up / Summer / towing a boat)
What you have is pretty safe.
Rem, your graph shows a WOT power run, so doesn't show other 'day to day' load cell results.
Edited by GeeTR
really? A:F ratio looks a bit rough, still good but could be a bit better?
PS - *my limited experience denotes my opinion means little*
Its the graph power curve thats important.
As long as the AFR's are safe, it doesnt matter if they jump around a little bit to achieve a brilliant curve like that :(
What would you prefer, slavishly tuning to a predetermined A/F ratio? And getting a rough power curve as a result? Or tuning for a smooth and progressive power curve and letting the A/F ratios fall wherever is best for power?
I know what I would choose.
Cheers
Gary
Is that RWKW??
Did you have a base figure? Curious as i want to do similar mods on my 33 GTR. Also what dumps and front pipe you running. Cheers Nick
RWKW, its not amazing power for a GTR, but I'm thoroughly impressed by the response of the car, and its only running stock turbo's in the end.
I am unsure about the front pipe, its a HKS super dragger muffler, 3inch exhaust system, it *might* be turbo back but I'm not sure.
The car has very few engine related mods, its all suspension and cooling mods...
Better get yourself some new Turbo's......
Pushing those figures it won't be long before the exhaust wheels go.
Could have saved a bit for Turbo's first then Powerfc with tune.
This was tuned by a trusted tuner, I didn't say "push the boost to 1 bar", he decided to put it there and I'm sure it will be fine, I have locked the boost controller so it won't accidentally get turned beyond 1 bar.
1bar is somewhere between 14 and 15 psi...? doesnt sound too high? I have the following to go on my 260RS -
3" exhaust inc front pipe and high flow cat, 600x300x100 fmic, apexi PFC, K&N panel filter in standard box. Running 1 bar i should see similar? are our setups fairly similar then?
Its running 1bar.
Perfectly fine for good condition GTR items, not a lot fail.
Its only those who push harder that see issues
Plenty of 1-bar GTR's around
Yes..correct Ash. I am all for what you are saying.
Assuming.....A 100% history of the car is available..and the Turbo's have not seen more than 100K of service.
Lets face it ceramic /exhaust wheels are not the most reliable things to have stuck on a 250KW GTR even RW.
some_cs_student
The tune you have is great...and the quality work your tuner has done for many on here is un-questionable.
I was just trying to say that if I had a GTR33 "Which I have" and it still ran stock Turbo's "Which you are",
this is one of the first recommendations I would have suggested before your tune.
My advice to you still stands.
Change your Turbo's :)
I have a stock intercooler, but similar mods performance wise. Drop me a PM when you get it tuned, I'm curious as to how you will go :)
Change your Turbo's :P
Point taken mate, I will do it *one* day, need to save up more $$$ first, and then I'll worry about going for aftermarket turbo's or high flowing them or similar.
The next concern would be with different turbo's, engine rebuild :D
Anyway, appreciate the advice :)
Gareth
I have a stock intercooler, but similar mods performance wise. Drop me a PM when you get it tuned, I'm curious as to how you will go :/
Will let you know. Hoping for 220 or so, but we'll see.
    • You know, that is exactly the thing that I was thinking a coupe of hours ago. I even had a plan for a meme, involving one big one, another big one, and the Old El Paso girl saying "¿por que no los dos?"
    • NoS, 2 of the big ones.
    • Oh, that's grim. Something bad has been happening there.
    • Put an endoscope down the hole and saw this. Not quite all around the bore but a good 60% at least. Chin to the chest and towards further disappointments I guess.
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
