Hi all... I am seriously considering selling my passage if i get genuine interest.
ok here comes the sales pitch:
* HR31 GT Passage Skyline
* White
* 4 door pillarless import
* 4 wheel steer
* IRS rear end
* LSD (tight)
* Power windows
* Power steering
* Air con
* Cruise Control
* Remote central locking/imboliser/alarm
* R32 RB20DET silver top ECCS (160kw)
* Odometer reads 128,000km.... replacement motor approx. 80,000kms
* EMS Dual Sport QI4/QM4 with Hand controller
* R32 5spd
* High Flowed R32 turbo with steel wheels
* K+N Pod
* Custom 600x270x55 intercooler
* 3" Exhaust straight thru
* PWR 3 core aluminium radiator, very large!!
* Adjustable boost control
* 550Hp Fuel pump
* Custom Whiteline rear sway bar
* Adjustable Koni coilovers all round
* R32 GTSt front brakes
* 300zx Rear brakes
* 17" Everim wheels with 225 front, 235 rear
* Spec Boost guage
* Blue/ Purple velour passage seats
* JVC MP3 player
* Pioneer 220w 6x9 (not installed yet)
interior is in very good condition, same with exterior.
Car is currently registered and hardly driven, except to work and back.
The car was dyno tuned and have been told wont make anymore power until the injectors are upgraded.
will email pics to anyone interested...
Located Northside of Brisbane
asking $12,000 ono
with everything .... let me know what you think please
https://www.sau.com.au/forums/topic/21065-fs-hr31-gt-passage-skyline/
yeh its an import, came standard with the RB20det.
insurance isnt too bad and i told Just Cars about every little thing on it and i pay about $20 more than a mate with a stock 92 Jzz30 2.5tt soarer.
Dyno was 236hp@wheels on 10psi... Limited by the injectors. Has all the support systems to go bigger, i just havent had the cash to get injectors, my choice would be 13BT. The EMS can handle any type of injector too.
any more info just ask :P
Cheers
Dave
can u give me an exat price on insurance for u ? i like the power figures, thats heaps good. Ill have to talk to dad about it seeing as its an import, i own an R33 dont know if i should go down to R31 turbo or not. Thanks for the info
  • 4 weeks later...
  • 4 weeks later...
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
