Was on the xr6T forum today. They were comparing the new F6 with the w427. There speculating the F6 will have around 600nm of torque and about 320-330kw, compared to the w427 with 370kw and 650nm? torque. the F6 will probably cost 1/2 the price and may actually keep up with the w427.
Now I think the R35 doesnt weigh all that much less than the F6 and w427. It has less torque than both and its power figure sits in the middle of both.
Would it be reasonable to say that the F6 or the w427 could out accelerate the R35 if they were rolling and did not loose traction?
Im not too keen on anything with 7L but the F6 with launch control could be a ball tearer.
https://www.sau.com.au/forums/topic/210659-straight-line-performance/
There was a comparison on the LS1 forums and the outcome of that discussion was that the R35 is quicker to 100 and down the quarter than it by a fair whack. So in short, in a straight line at least, no those cars couldn't keep up.
Well hard to say, I dont really know what both of the local offerings will hit the scales at. I know the GTR is heavy but it does make as much as the 427...I would still tip the Skyline to be a bit quicker.I believe one of the latest motor magazines compares some 427 holden against BMW and Merc.This car was tested making 400 kw ( according to the magazine )..it was quicker than both, but it only ran a 12.8 according to their tests..I am not sure this is the same car as HSV is building ( Maybe an aftermarket job ) but a 12.8 ..? I was expecting a low 12 or high 11 ...Dont really know much about what Ford is building. Potential is there to be fast..who knows
There's probably enough literature and automotive tests on w427 and the R35 (japanese version) to make a punt on who'd come out quicker. But then again, it's not really a fair comparison as the R35 has two less doors and is built ground up as a competitor to the Porsche 911.
i would have thought this would be due to traction. i have a feeling if they were rolling and had no traction loss these cars would keep up.
No way will the F6 come out with 320+kw, try 300...and no they won't compete with the GT-R.
The W427 and Typhoon will both be using either manuals or torque converting autos. Even if all else was equal, they wouldn't keep up on that alone.
The 997 Turbo has the same power and less weight than the GT-R (and both are AWD with fat, soft, rubber), but as it doesn't have the instantaneous gearchanges the cars are line ball in a straight line. The two cars' manuals are nowhere near as smooth and easy to use as the Porsche's, so they'll be slower. If you got the autos, they're only marginally quicker than the manual cars.
Unfortunately, not all else is equal. The GT-R's aerodynamics are far better than the two sedans', so once you get up to speed the GT-R will still dominate.
Only if you're talking about an high-gear roll start at low speeds and the R35 is off-boost will the 7.0L Holden have a chance of winning.
I would have to say the GTR, namely
horsepower / weight similar?
traction superior
gearbox changes faster
launch control
For the Ford to be quicker,
- it needs to match the traction (i.e. not one of those dodgy systems where the car puts on the brakes to stop wheel spin in acceleration. So without AWD, and assuming a good TCS then it would need the right tyres to make up for this
- gearbox either needs as quick a gearchange or no change at all i.e. 1st gear all the way to 100km/hr
launch control or an ace driver to make up for the balance of revs/wheelspin without smokin' it or bogging down
So it might be possible with equivalent power/weight and an 'ace' driver to keep up / maybe win but then the GTR will have repeatable performance.
A guy I worked with modded his XR6T so it had 355hp at the rears and it used to freak him out, the traction control would cut in and slow the car down enough to make him think he was going to get t-boned! it shows that a RWD TCS is not really a match for an AWD
Also if you haven't seen this article from Edmunds, then it is not too bad a read - especially for Nissan fans
http://www.edmunds.com/apps/vdpcontainers/...rticleId=124017
A rolling start certainly doesnt take traction out of the equation
Lets think about that, based on my post that we're responding directly to Amir's question in the first post of this thread?
(Emphasis added by me, spelling mistake is by him)
Would you care to revise your statement, given the context of his question?
Edited by scathing
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
    • The fact that US/JDM plates actually fit the skyline bumpers properly is a big, big thing for me as they are the correct dimensions. Annoyingly you can't opt for a normal plate (or plate combination) in that size. You have to make up your own one, and at that point you'd still know it wasn't randomly assigned.
    • Well, really, that's any ECU, because it's not so much the ECU that the tuner connects to, but a laptop that's connected to the ECU. You have to have the tuning software installed locally. The "remote" part is essentially just remote desktop (RDP) or VNC type access. Nevertheless, if you're looking to upgrade, then you're immediately in the Haltech/Link territory, both of which can be done by any number of competent tuners here in Oz. But without a dyno, you'll definitely also need a wideband O2 sensor fitted, and you'll probably be relying on "auto" tuning a bit, where you drive it around under various loads and then apply the corrections that the ECU learns (basically applying the fuel trims that the ECU has to do to correct the mixtures). Tuning the timing is a little harder. It can be difficult to trust the old OEM knock sensors on RBs, so it is definitely best to have someone who knows what they're listening for, with knock ears (a piezo microphone connected to the engine, and and little amp and headphones so the listener can hear the angry men with hammers who live in the engine). That is more difficult to do remotely, and I suspect the only sane way is to be quite conservative on timing. But that's OK. You're probably waaaaay better off with conservative timing where you are. What is the fuel situation? 98RON available? Or low grade jungle juice?
    • I see your point, I didn't think too deep into it, was purely focused on the price. There's no bad blood between myself and GSM, they acknowledged the price was cheaper else where and at the time couldn't match it.
