hey guys/girls
i got a Beltronics Vector LR that i received of a mate for free as he said it wasn’t working last time he checked. i found a power connection for it and turned it on, and as my mate said, it comes with a error.. it starts of normal and comes up with the normal start up display but after about 5-10 seconds of being on it comes up with . " ?LO1 CAL" i asked some of my friends and one said it may be a calibration error.
Does anyone know what this error is or what " ?LO1 CAL" stands for. also does anyone know whether this problem is fixable and if so an approx. price.
Thanks any help appreciated niran
https://www.sau.com.au/forums/topic/210675-radar-detector/
hey guys/girls
I found that powering it on from cold it worked fine, if it was in the sun for too long it would start giving me that error. Lucky for me it was still within it's 3 year warranty and I took it to a supplier and repairer and they actually replaced it (and with a newer model), place was called Neltronics in Subi.
https://www.sau.com.au/forums/topic/210675-radar-detector/#findComment-3724498
hey guys
i rang up neltronics however the number that was on yellow pages, does not work.. If i try ringing, it just says the call could not be connected. the number i dialled was (08) 9388 9950, does anyone else know of another number for this store??
Thank’s
niran
https://www.sau.com.au/forums/topic/210675-radar-detector/#findComment-3725306
OK.. here's the story...
"LO CAL" (or "MARKERS" or "PLL LCK") is a fault code describing some kind of error has occured during a calibration test. BELTRONICS are keeping their software to themselves to avoid Chinese manufacturers from reverse engineering their products and whacking on the software... smart hey! :)
To repair this issue we would hopefully have a replacement board here in stock... we simply open up your faulty unit... put in the refurbished board... set up the menu and bands and away you go. The faulty board is then shipped to BELTRONICS to be refurbished and reflashed with new software.
The software repair is $95.
In WA cops use:
Multanova (not multinova!!!) which is a Ka band radar signal... low output so hard to detect
Patrol cars which use a K band radar signal... strong power so easy to detect... BUT... remember not every car is equiped and if they are, they might not be turned on
Sgt Plod himself uses a hand held laser signal... very strong, very fast, very accurate, VERY NARROW so damn hard to detect unless its fired right at your detector at which point they probably have you anyway.
That concludes todays lesson kiddies... now you can all go home, except Ossie... come here for a touching!
https://www.sau.com.au/forums/topic/210675-radar-detector/#findComment-3726617
$95 to repair? What about warranty ;)
Need I say more!!!
Plus the fact that a Vector LR came out around 9-10 years ago with a 1 year warranty.
Pulp, what unit do you have?
https://www.sau.com.au/forums/topic/210675-radar-detector/#findComment-3727163
    • Just to give an update coilovers passed without any issue!
    • Ducan , yeah sure mate , the unit is https://www.carlinkit.com/ambient TBox Ambient -  plugs straight into the USB C and it runs as a android  unit and you can link your phone to it via Bluetooth , but it only allows for one phone at a time. you can download and apk files you want and load it on there , I downloaded a basic maps apk (OsmAnd+ — Maps & GPS Offline) so I can run navigation without data usage , its not as good at google or wazes but it works fine for what I need. I can put up screen shots if you like. Cheers Pac
    • Hey Team , just got the Fujitsubo unit installed , not a big db difference but it does sound better across the rpm range , I have the front pipe on order I'll post a video with sounds when that has also been installed.
    • The gearbox in my R32 GTS4 (now with RB25DET) has just over 300k on it . Life includes some track time. Has had one change of oil in its lifetime. I rev match on down changes. I don't have any problems with synchros or gear crunching.
    • Currently advertised with some A4 flyers up at work for $30k ono Will detail it next week, and get some good picks for carsales, then put the cover back on and put it back on the tender until someone comes to look at it No real hurry to sell, in saying this I would like it gone with in 6 months as I am retiring in May 25 and lose the ability to store the car undercover in a secured site, plus as we are moving out of Sydney the potential buyers market will be more limited https://www.sau.com.au/forums/topic/485907-2002-vx-ss-commodore-30000-ono/
