Hey guys
My cefiros suspension/steering setup is in fairly poor form. I need everything replaced, all tie rods,bushes, coilovers, steering rack etc.
Can someone reccomend me a list of stuff that would make my ceffy handle like a new again. Also if there are any Kits (tie rods etc) out there and what coilovers people have found to be smooth. I use the car predominantly for the street and hills so I prefer better handling.
thanks
Kim
Edited by Starionturbo
https://www.sau.com.au/forums/topic/210744-cefiro-suspension-setup/
Have a chat to sydney kid on these forums. He sorted mine out. Basically what I think you would want is a softer version of my set up, especially if doing some mountain stuff. Mine is a little too stiff I feel still.
    • Yeah i have R34 with factory small box and now RB25DET NEO swapoed and iam planning to upgrade to big box.  So i would be good as long as i do not change diff?
    • Based off what you’ve said here, I think I’ve figured out a good bit of what I’ve done wrong -  So on the line going from the PCV valve to carbon canister, there’s a T joint that is pretty much right next to that lower port - I hadn’t noticed that the hose in the diagram was curved to attach onto the carb, so I was putting that line for the lower port onto the PCV line / carbon canister line instead. I’m going to have a flick through the manual again tomorrow and should hopefully find a diagram that’ll show me where that T joint should be connected to. Timing also 100% needs to be sorted out as well, should be able to tackle that tomorrow as well. Definitely feel like I should be on the right track now though.
    • The screw is for idle (pilot circuit) mixture adjustment. Else, I'm confused ~ the diagram shows 2 carby ports, and the intake manifold port, but you're suggesting the "2nd port on the back of the carb that isn’t mentioned in the diagrams" ...yet, both carby ports are shown...que?... ...in any event, that port should be connected, but if not (like it is now), it's unlikely to cause a backfire out the carby (it would introduce false air and give you a fast/lean idle) ...sounds more like timing issues/spark plug wire routing responsible for the backfiring.
    • That's fair, I can see both points. I get enthusiastic when I see the FS section has a new post and want to see what interesting thing someone is selling. Then I get deflated it's a bump of a 10 year old post. Ha ha
