Hey guys, getting a new turbo in a few weeks, pretty much i dont wanna mess around trying to install it, just not confident in doing it... Where do you guys recommend I go to get my turbo installed and how much am i looking at for the job? Its a direct bolt on turbo (T3 flange/6 bolt) so yeahh any suggestions would be great..
Thanks
https://www.sau.com.au/forums/topic/210751-where-to-get-turbo-installed/
  • Replies 40
Do you have a tunable ECU? If not any mechanic can change the turbo over, if you're getting it tuned then you want to go to one of the well known places that know their stuff with your particular ECU, Racepace, RE etc.
Im not too sure if i have a tunable ECU its just the stock ECU pretty much how could i tell? Because i was going to get it re-mapped when i install everything..
Just gave a call to RE they quoted me about $350, i might ring around but try to get RE to drop it to $300 for the 1 day job we'll see how it goes since springvale is closer to me
lol... $350 for a turbo install, and your trying to jew them down another $50?
Jesus man... $350 is already a very fair and reasonable price for the work involved.
I would have thought $500 personally.
As for the rest - there are a dozen workshops in the Workshop sticky...
haha ima jew all i can man this upgrade's gonna cost me a small fortune have to cut costs any way that i can =P but yeahh no harm in trying to drop $50 lol
Dude - if you cant afford to mod it, then you don't :(
Do it once the right way, or not at all as it'll end up costing you more.
Thats the one thing i've learnt in the 6-7 years i've been playing with cars, and mainly RB's.
If owned a workshop and you asked me to knock off 50, i'd probably add 50 for the point and make it 400 :)
Dude - if you cant afford to mod it, then you don't :dry:
If owned a workshop and you asked me to knock off 50, i'd probably add 50 for the point and make it 400 :P
Yeah and i'd say thanks but no thanks and go somewhere else ;)
Nahhh i can afford it, but theres no harm in trying to bargain a little
Hmmm might have to give a ring to a few of these other places you guys have been suggesting.. if i went to RE or anywhere else for that matter, would they supply water lines if needed?
Turbo is http://horsepowerinabox.com/HPIAB2/category12_1.htm#643 ... Abu said i could use the stock oil/water lines but theres a note saying:
** please note the Garrett GT series turbos have a M14 water outlet size rather than the larger Nissan RB20/25 size outlet so water lines will have to be revised**
Edited by cosmokram3r
For sure mate. That'll go on the invoice as well.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
