Hey guys, getting a new turbo in a few weeks, pretty much i dont wanna mess around trying to install it, just not confident in doing it... Where do you guys recommend I go to get my turbo installed and how much am i looking at for the job? Its a direct bolt on turbo (T3 flange/6 bolt) so yeahh any suggestions would be great..
Thanks
https://www.sau.com.au/forums/topic/210751-where-to-get-turbo-installed/
  • Replies 40
Do you have a tunable ECU? If not any mechanic can change the turbo over, if you're getting it tuned then you want to go to one of the well known places that know their stuff with your particular ECU, Racepace, RE etc.
Im not too sure if i have a tunable ECU its just the stock ECU pretty much how could i tell? Because i was going to get it re-mapped when i install everything..
Just gave a call to RE they quoted me about $350, i might ring around but try to get RE to drop it to $300 for the 1 day job we'll see how it goes since springvale is closer to me
lol... $350 for a turbo install, and your trying to jew them down another $50?
Jesus man... $350 is already a very fair and reasonable price for the work involved.
I would have thought $500 personally.
As for the rest - there are a dozen workshops in the Workshop sticky...
  cosmokram3r said:
haha ima jew all i can man this upgrade's gonna cost me a small fortune have to cut costs any way that i can =P but yeahh no harm in trying to drop $50 lol
Dude - if you cant afford to mod it, then you don't :(
Do it once the right way, or not at all as it'll end up costing you more.
Thats the one thing i've learnt in the 6-7 years i've been playing with cars, and mainly RB's.
If owned a workshop and you asked me to knock off 50, i'd probably add 50 for the point and make it 400 :)
  R31Nismoid said:
Dude - if you cant afford to mod it, then you don't :dry:
If owned a workshop and you asked me to knock off 50, i'd probably add 50 for the point and make it 400 :P
Yeah and i'd say thanks but no thanks and go somewhere else ;)
Nahhh i can afford it, but theres no harm in trying to bargain a little
Hmmm might have to give a ring to a few of these other places you guys have been suggesting.. if i went to RE or anywhere else for that matter, would they supply water lines if needed?
Turbo is http://horsepowerinabox.com/HPIAB2/category12_1.htm#643 ... Abu said i could use the stock oil/water lines but theres a note saying:
** please note the Garrett GT series turbos have a M14 water outlet size rather than the larger Nissan RB20/25 size outlet so water lines will have to be revised**
Edited by cosmokram3r
For sure mate. That'll go on the invoice as well.
    • That's the thing....the basics of fuel and ignition are deceptively simple.....getting it to behave like factory in all conditions after airflow mods is way more complex. Newer cars like the V37 are all about modifying the standard ECU which is about a billion times more complex than they were 20 years ago, with a bunch of parameters affecting others
    • The larger TB I had on the SS was a pain to get to idle right, but, that was cable In the end they just raised the idle up a couple of hundred RPM so it was happy idling away either in gear or in park (slush box life) I'm curious on how my NC will idle with the new intake, larger TB, and cams that are currently going in/on, but I have faith that MX5 Mania will sort this "electronical" "black magic" out the best they can in the tune with a electronic TB Sometimes I wish I knew more about the intricacies of tuning, but most of the time I don't because I know it would hurt my brain 馃ぃ
    • That's the thing. Cam is smaller than before.. though the old cam was +6 degrees advanced. We're talking huge changes here, the narrowbands want to trim out 20% of fuel and pull the (wideband) idle to like 16.0 AFR or such. One side is a little more trimmy than the other. Think along the lines of ~20% to ~15-18%. Unfortunately my scouring of the internet hasn't really found anyone with this issue. People either just disable NB's or have them wildly different, where one is -20% and the other is +20 or 0 (i.e a sensor is just dead/wiring is just busted). Turning them off and relying on the base map only results in the wideband reporting at about 14.0 with the Varex closed. It'd be a little leaner (closer to 14.7ish) with the Varex open. I know I can just change the switch points so that the narrowbands agree with the wideband, but it's still odd. Both of them are reading voltage, it's just that they're reading quite high mv, in the ~800 region. It's just odd. This was with the IAT fudged to report it was about ~22 degrees which is my guesstimation of the temperature in the room. I have an OEM sensor ready to try tonight, which is slow and crap - but .. worked last time I used it. Sadly I am aware that idle tuning with the big TB is going to be a PITA and I look 'forward' to many hours spent stalling or stumbling idle or delving into drivability things.
    • The GTR strut brace clears the new manifold.. by about 0.5mm. So this means I need to buy an OEM GTT Strut brace (again), which will clear the new manifold, but not the bonnet vents. I guess I can sell the GTR Strut brace with the bonnet with the vents as a package deal as someone will need this one day. So my choices are vented bonnet but no strut brace, or GTR Bonnet with OEM brace (which I have to buy) but is bright red instead of the same colour as the rest of the car, which means the entire front end of the car will just be red until it goes back to paint jail. In other news the engine starts and doesn't leak. Why both O2 narrowband sensors think the tune is rich AF I do not know. The idle is also pretty shitty and my expensive IAT sensor from the USA is dead. The car sounds awful. But I assume or at least hope this is due to the many exhaust leaks, and the concrete garage it is in, sitting there with 0 intake bolted to it, and no bonnet or panels or anything to stop the induction/intake sound which is about 200db.
