Tubemite Joint. For Welding All Sorts Of Pipes!
Ok, I stumbled onto this little calculator
Its not very big in size but does the best job EVER!
just donwload it and save it to somewhere where it wont be lost!
It is used for joining pipes of all sorts of sizes and angles: for instance
If you wanted to join a 50mm screamer wastegate pipe into you 76mm dump pipe, and you wanted the WG pipe to entre the dump pipe at 30degrees, with a wall thickness of 1.2mm...
you just plug the numbers into the little calculator via the 'options' menu and you can print out to real life size little pic. just cut the little pic out and tape it together around ur pipe. draw the lines onto your pipe and cut!
now its not done yet.. because it takes into account for wall thickness, it has 2 lines.. solid is the inside of the pipe and the dotted is the outside of the pipe! so it fits PERFECTLY!
So now you can cut once.. get it perfect and save yourself heaps of fustration!
http://www.ozhpv.org.au/shed/tubemiter.htm
it is limited to only 2 pipes, so you wont be building manifolds just yet! But i think with a little thought, it would not be hard to adapt to do multiple pipes.. after all, if its on paper, its easy to cut!
Edited by psi
I've had a program like this for a few years now, the old man pointed me in the direction of it.
Something to do with the fact of him getting sick of me constantly asking him i guess :blink:
  • 1 month later...
Yea it sure is a great program.
If anybody finds a program that is able to cope with multiple pipes, PLEASE post it up!
I have sort of stuffed around with making a paper exhaust manifold (just because!) and i think that if you cut 3 bits of paper for the one pipe and rotate them so they notch properly into the other pipes.. but i ran out of time and my 3 year old turned it into paper mash! aaaarrghh!
pipe notcher.. hmm, can u get it to do multiple pipe joins? research time!
  • 10 months later...
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
