Looking into fuel pumps at the moment. Have had quite a few quotes so far...
All the nismo, Tomei etc etc fuel pumps are all around the high $400 mark...
Sard slightly cheaper...
And then Bosch and Walbro around the $200 mark...
Would they be ok for around 300kws in a R33 GTR?
It will be a DIY so i know nismo would be the easiest to put in but for half the price its worth a bit of mucking around...
any ideas?
Or any one used these pumps, pros cons?
Have searched and had mixed results from all those pumps!!!
Or if anyone can get them cheaper or know where i could get them cheaper???
cheers
https://www.sau.com.au/forums/topic/210788-fuel-pumps/
Personally i'd go Nismo or HKS. It's a little more but it's much easier to work with. Bosch are good (i have the 040, no complaints) but in R33's at least, can't reach the bottom of the tank and aren't as reliable on hard cornering, but i just don't dry the tank out so isn't an issue.
Also there's no cradle modifying with these drop in pumps. If you REALLY want to save money go Bosch/Tomei, but on a GTR especially you want something reliable and for an extra $200 you're getting an easier job and less to worry about down the track.
My 2c
https://www.sau.com.au/forums/topic/210788-fuel-pumps/#findComment-3726452
My 2c
You won't save much money buying the Tomei when It's around the same price as Nismo and HKS
https://www.sau.com.au/forums/topic/210788-fuel-pumps/#findComment-3726473
So many threads bout pumps, im getting dizzy :)
Its not that hard.
If you don't want to fiddle, cant use hand tools and want a solution you prolly wont have to think about… ever again, then slap ½ a G on a Nismo bolt in – Done, so simple, you'll forget which pump you have when asked.
If you live to tweak, can use hand tools, and don't mind playing around with things, then go the non bolt in option, and stick in your [iNSERT PUMP MODEL HERE] in tank.
The pump has NOTHING to do with G forces, fuel gauge etc blah blah. Clearly one needs to mount the pick up sock in the same location as factory… to get the same factory result. This means not using 2nd hand hay twine to tie the pump half way up the cradle support. It means thinking about line flex, material, line runs etc, as to not impact other systems.
/end rant haha :(
Edited by GeeTR
https://www.sau.com.au/forums/topic/210788-fuel-pumps/#findComment-3726514
+1 nismo [and I am handy with tools]
U then, clearly possese a spagina, and like man tools :)
Jokes :nyaanyaa:
No worries = plug in. Save some $ = doit urself - if i was rich and had no care for mechanical symbiosis... id go Nismo too (and debate it black N blue)
Edited by GeeTR
https://www.sau.com.au/forums/topic/210788-fuel-pumps/#findComment-3727543
Me, if I fitted a bosch, I'd weld up a frame that the bosch would sit in just like a std pump, then I'd get the frame bright zinc coated so it wouldn't rust etc then I'd be half happy---------but this would cost as much as a nismo in the end and be a bit more mucking about------------and don't tell me I'm overdoing it, I've fought my pedanticism all my life and lost every time.
If I didn't do it like that I'd be going down the road saying 'Yeah, I got a bosch, but I'm going to take it out and fix it up soon!!!' and would always be nagging/noring away at me until I did.
https://www.sau.com.au/forums/topic/210788-fuel-pumps/#findComment-3727786
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
